Something other than a cog belt for driving axis May 26, 2012 09:34PM |
Re: Something other than a cog belt for driving axis May 27, 2012 04:18AM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Something other than a cog belt for driving axis May 27, 2012 04:31AM |
Re: Something other than a cog belt for driving axis May 27, 2012 04:45AM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: Something other than a cog belt for driving axis May 27, 2012 05:08AM |
Re: Something other than a cog belt for driving axis May 27, 2012 10:44AM |
A new series of Synchromesh Cable Drives introduced by Stock Drive Products are uniquely designed for positive traction to replace conventional ropes, simple cables and cog drives, especially where tight space is an important factor. This new cable drive is designed to provide high precision positioning in electronic equipment such as: copying machines, X-Y plotters, typewriters, printers, word processors, etc. A key feature of the new drive is its ability to be used in three-dimensional serpentine configurations which enable the creation of extremely miniature designs.
Synchromesh cable can be used with lower tension when compared with ropes which reduces power consumption. Unlike ropes, wind-up around drums is not required which eliminates problems with dislocated printing caused by accumulation of elongation when rope is used due to wind-up.
This patented miniature cable, identified as the A 6J 9- and
A 6J 9M Series, consists of a straight center section, encased in Nylon and a helically wound outer length encased in Polyurethane. Both cable strands consist of braided stainless steel cores.
Re: Something other than a cog belt for driving axis May 27, 2012 08:30PM |
Re: Something other than a cog belt for driving axis May 27, 2012 09:42PM |
Re: Something other than a cog belt for driving axis May 28, 2012 03:32PM |
Re: Something other than a cog belt for driving axis May 28, 2012 04:08PM |
Admin Registered: 18 years ago Posts: 14,148 |
Re: Something other than a cog belt for driving axis May 28, 2012 04:15PM |
