Ramps 1.3 with a fan not on normal mosfet
Posted by Enlightx
October 06, 2012 03:06PM
hi guys
just built my 1st ramps 1.3 board (been using a Sanguinololu before)
problem is i need to connect my fan up.
im using this for my fan (http://www.thingiverse.com/thing:22202
all the threads im reading tell people to connect there fans to pin 9 mosfet output. problem with this is i want to use a second extruder at some point and as i already have a moset setup and ready to go i see no point in this.
any ideas which pin on the ramps 1.3 i should connect to and what to set it in pins.h as?
Re: Ramps 1.3 with a fan not on normal mosfet
October 06, 2012 05:37PM
I'd use pin9 until I had the second extruder finished, and worry about it then.
You can also connect the fan directly to 12v and a switch, and power it when needed. I find I can't have my fan turn on and off as it fluctuates the temperature too much for PID to keep up.
But you can use any spare pin to hook up a fan. From this schematic [reprap.org] pick one from AUX-4, and make the appropriate changes to the firmware.
-Nudel
Blog with RepRap Comic
October 07, 2012 09:30AM
got it sorted
had a look intot he pins.h after selecting board 34 (2 extruders 1 bed) from the config.h file
by default in marlin RC3 if pin 9 is in use it uses digital pin 4
which is bottom right of the servo set of pins
only problem with ramps no header for the 12V feed for the fan so had to just put it in with the 5A 12V+ line
works a treat
