Best Value Bits For RoStock
Posted by cjflis
September 04, 2012 02:07AM
Hello all,
I have the plastic parts of a Rostock printer on the way and I am wondering which parts I should use.
I have got a list as follows but would like your input, if you think there is a better option for a similar price.
Bearings:
4x 608ZZ + 3 with printed flange.
[www.radicalscooters.com.au]
MR105ZZ
[helidirect.com]
6x LM8UU
[create3d.com.au]
Stepper Motors
4x Nema 17
[www.osmtec.com]
Smooth rod:
6x 762x8 mm precision smooth rod.
I am unsure were to get these, I would like them in larger dimensions
Pulleys
Timing belt pulleys: 3x GT2 plastic pulleys with 40 teeth
Timing belt: 3x 1524 mm GT2 belt (2 mm pitch).
Also unsure about these
Electronics
RAMPS 1.4, Is this the best?
That's the list for now, will probably sort out the rest once these parts are chosen.
And one more question, are 1.8 degrees the best motors? And should i just buy the strongest motor I can afford?
Thanks everybody, sorry for so many questions!
Re: Best Value Bits For RoStock
September 04, 2012 06:30AM
Check out the electronics from Roy @ Panucatt . We have been very happy with his Azteeg Electronics.
You can get the pulleys and belts from SDP-SI although I'm not sure if these are the least expensive.
Chelsea - QU-BD
September 04, 2012 08:07AM
for belts and pulleys, I like econobelts.com
for rods, blocks and bearings, i like vxb.com
for carbon fiber rod, I like goodwinds.com
September 04, 2012 10:21PM
Thanks guys,
Chelse what type of board am I looking for?
And dave why did you use CF rods overs steel or stainless steel?
Thanks for the replys guys!
September 04, 2012 10:58PM
The Azteeg X1 and X3. The X3 is the dual extruder capable version.
Chelsea - QU-BD
September 04, 2012 11:26PM
light weight and cheap, I guess.
I got some carbon fiber rods, 1/2" dia , 24" for $4 each.
I also got some 5/8" dia fiberglass, 42" long for $7 each
I am going to make a big one.
Dave
September 05, 2012 12:38AM
Okay Thanks Helsea, how does a dual extruder work? And can it work on a RoStock?
And thanks Dave, I think I will go with CF for the arms and Stainless for the Uprights.
Also are the rods just glued to the plastics or do they screw in?
Thanks,
CJ
September 05, 2012 08:17AM
I plan on making a simple pin jig to ensure the rods are all the same length.
Just a board with pins spaced the distance i need.
I am going to glue plastic adapters into the ends, with the VXB rod ends.
kind of permanent, unless I cut it all apart.
you need to evaluate your own sizes for stuff.
My goal is rather large, with 40 inch rods, 5 foot towers.
If you are planning on using Johan's Rostock bits without changes, take my advice with a grain of salt.
Dave
open | download - POS10.jpg (15.6 KB)
September 05, 2012 10:11PM
To print something that is 45" tall i would need to make the rods more like 60" wouldn't I as the arms cant go all the way up?
September 05, 2012 11:21PM
for 45" tall, yes you need to scale everything up. I think that is the first you've mentioned that desire.
you might struggle finding 8mm ground rod in long lengths also. They are flimsy and 30" is the longest unsupported round that VXB sells.
You might also consider spreading out the towers at the same time.
have you considered printing laying down, or dividing the part and glueing?
If you use Solidworks, I can give you my basic assembly, which you can scale and try out some dimensions.
It has basic constructs so it moves easily and helps with the brainstorming.
I could also IGES or STEP it out, or even STL or ??
September 06, 2012 01:36AM
Okay no that dimension was just for an idea, but I would like it as big as is possible without having to lie to down or anything. So is 40" the max?
September 06, 2012 08:45AM
I would say there is no max.
It all depends on your scale.
October 21, 2012 12:20PM
Here are smooth rods for a Rostock on McMaster Car
Smooth Rods (6x etc):
Tight-Tolerance Rods—Metric Sizes—Precision Ground Finish
[www.mcmaster.com]
