Living with a bottom Z limit switch May 30, 2012 01:14PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Living with a bottom Z limit switch May 30, 2012 01:32PM |
Re: Living with a bottom Z limit switch May 30, 2012 01:58PM |
Re: Living with a bottom Z limit switch May 30, 2012 02:10PM |
Re: Living with a bottom Z limit switch May 30, 2012 02:29PM |
Re: Living with a bottom Z limit switch May 30, 2012 02:39PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Living with a bottom Z limit switch May 30, 2012 03:14PM |
Re: Living with a bottom Z limit switch May 30, 2012 03:15PM |
Re: Living with a bottom Z limit switch May 30, 2012 05:04PM |
Re: Living with a bottom Z limit switch May 30, 2012 06:02PM |
Why can't you just, home to a Z position above the build platform, then set your soft limits to be 1mm below the point (or however far your bed is)?
Re: Living with a bottom Z limit switch May 30, 2012 06:29PM |
Re: Living with a bottom Z limit switch May 30, 2012 06:32PM |
Re: Living with a bottom Z limit switch May 30, 2012 07:04PM |
Re: Living with a bottom Z limit switch May 31, 2012 03:29AM |
Re: Living with a bottom Z limit switch May 31, 2012 06:43AM |
Re: Living with a bottom Z limit switch May 31, 2012 04:26PM |
Re: Living with a bottom Z limit switch June 12, 2012 11:17AM |
Re: Living with a bottom Z limit switch June 12, 2012 12:24PM |
i m havin problem with homing and limit switchin and one main problem is Z axis moving after hittin limit switch small unit up and down October 22, 2015 06:44AM |
homing and limit switching problem October 22, 2015 06:52AM |
