Printer problems
Posted by CharlieSteurbaut
Printer problems
December 06, 2012 12:11PM
Hello,
Can someon give me his opinion what the cause is that my print moves sometimes. What i mean is that it prints a couple of layers and then the hole print is moved 5 mm or so.
Also what modifications can i do to my prusa mendel to have a flat print?
If you look at the picture you can see that the walls are not perfectly flat.
Charlie
open | download - Foto.jpg (88 KB)
Re: Printer problems
December 06, 2012 01:23PM
I looked at your picture and it's showing your extruder....
A few things that can cause various amounts of shifting(lost steps)
-stepper drives are not adjusted properly. (need to increase current going to the motors)
-Firmware or print speeds are too high for your machine.(try lower print speeds)
-Belts are too tight
-Damaged belts(metal reinforcement/bands in the belts are broken)
-Motors are underdriven
