rod length
Posted by sadistic_angel
rod length
January 04, 2013 04:45PM
WOW that title sounded better in my head.
anyway I am making the Wallace reprap [ here ]
I'm wondering what lengths i need to cut my smooth and threaded rods, i'm hoping for 200x200x200 build space but smaller or larger is fine, is there a ratio or something i could use? or a certain length that the threaded rod has to be longer/shorter than the smooth? thanks!
Edited 1 time(s). Last edit at 01/04/2013 04:54PM by sadistic_angel.
Re: rod length
January 06, 2013 07:14PM
from wiki:
smooth rods
measurements will depend on desired build volume. 350 mm X 320mm X 350mm
gives about 200 x 200 x 170mm
as for threaded rod it depends on build volume. since the threaded rods go along the same direction as the smooth rods on z axis i would say start off with 350mm - 50mm less for area obstructed by motor=300mm for z axis.
for x and y, there are limits to bed size, so 350 and 320 will work within the size of the bed, and probably will be too long.
imho, i hope this helps.
someone probably should specifically state the threaded rod size in wiki, it will make newcomers a lot less nervous.
