Hi HereIgoAgain. Your question is a litte ambiguos. Let me try and clarify it, so you get the answers you need. Do you mean
A. Is any one "planning" to use a Lulzbot's Budaschnozzle 1.1 hot end with a Wade's extruder in a modified X-Carriage?
B. Does anyone have an X-Carriage design file that works with Lulzbot's Budaschnozzle 1.1 and a Wade's extruder?
I think you mean "B", so you should tell a little about your machine, like what type of RepRap design it is, and why any X-Carriage designs you have found are not working.
If you look at thebottom of the
Lulzbot page of the Budaschnozzle 1.1, there is a note on where to find the right knid of X-Carriage for the hot end.
Lulzbot Website
NOTE: The Budaschnozzle is not compatible with Greg Frost's lm8uu linear bearing x-carriage or the MakerGear x-carriage. For lm8uu bearings you will need Prusa's lm8uu carriage. You can find it
here. For use with the MakerGear Prusa you will need
this x-carriage and plastruder body.
