TMI. RepRap circles. January 27, 2013 05:50PM |
Re: TMI. RepRap circles. January 27, 2013 05:55PM |
Re: TMI. RepRap circles. January 27, 2013 06:28PM |
Re: TMI. RepRap circles. January 27, 2013 07:05PM |
Re: TMI. RepRap circles. January 27, 2013 07:16PM |
Re: TMI. RepRap circles. January 27, 2013 07:22PM |
Re: TMI. RepRap circles. January 27, 2013 07:39PM |
Re: TMI. RepRap circles. January 27, 2013 07:41PM |
Re: TMI. RepRap circles. January 27, 2013 07:53PM |
Re: TMI. RepRap circles. January 27, 2013 08:29PM |
Re: TMI. RepRap circles. January 27, 2013 09:44PM |
So what is your ultimate goal with a 3D printer?
Re: TMI. RepRap circles. January 27, 2013 09:55PM |
Admin Registered: 11 years ago Posts: 1,063 |
Re: TMI. RepRap circles. January 27, 2013 10:01PM |
Vitamins: E x t r u d e r c E X o x n t S c E n r p a l e u o X r Y e c d P o r c E t e r l c i c B t x i r H M i a a X X a Y Y Z e r t o o a n h X r g Y r Z d o r n m F t c t o r e i m r i m m n u o r h l a i d o a i d o a o f i d p t a e i b P d x a f l t x a l t x t a c e c o m n n e s e i g a e o i g e o i o n s r b r e d e d u r s e n r r s e r r s r | | | | | 1| | | | | | | | | | | | | | | | | 1 Acrylic sheet 471mm x 422mm x 10mm | | | | | 2| | | | | | | | | | | | | | | | | 2 Acrylic sheet 165mm x 389mm x 6mm | | | | | | | | | | | | | | | | | 1| | | | | 1 Acrylic sheet 217mm x 217mm x 6mm | | | | | 1| | | | | | | | | | | | | | | | | 1 Acrylic sheet 471mm x 389mm x 6mm | | | | | | | | | 1| | | | | | | | | | | | | 1 THS15 Aluminium clad resistor 10R | | | | | | | | | 1| | | | | | | | | | | | | 1 THS15 Aluminium clad resistor 4R7 | | | | | | | | 5| | | | | | | | | | | | | | 5 Aluminium foil tape 50mm x 227mm x 0.05mm | | | | | | | | | 1| | | | | | | | | | | | | 1 PSU e.g. ALPINE500 | | 3| | | | | | | | 4| | | | | | | | | | | | 7 Ball bearing 608 8mm x 22mm x 7mm | | | | | | | | | | | | | | 2| | | | 2| | | | 4 Ball bearing 624 4mm x 13mm x 5mm | | | | | | | | 4| | | | | | | | | | | | | | 4 19mm bulldog clip | | | | | | | | 1| | | | | | | | | | | | | | 1 PCB bed 214mm x 214mm | | | | | | | | | | | | | | | | 1| | | | | | 1 Belt T5 x 6mm x 655mm | | | | | | | | | | | 1| | | | | | | | | | | 1 Belt T5 x 6mm x 870mm | | | | | | | | 1| | | | | | | | | | | | | | 1 Corrugated cardboard 193mm x 217mm x 6mm | | | | | | | | 4| | | | 2| | | | | | | | | | 6 M3 cap screw x 10mm | 4| | | | | | | | | | | | | | | | | | | | | 4 M3 cap screw x 12mm | | 3| | | | | | | | | | | | | 4| 4|14| | | 2| 2| 29 M3 cap screw x 16mm | | | | | | | | | | | | 1| | | 2| | 2| | | | 8| 13 M3 cap screw x 20mm | | | | | | | | | | | | 2| | | | | | | | | | 2 M3 cap screw x 25mm | | | | 2| | | | | | | | | | | | | | | | | | 2 M3 cap screw x 45mm 4| | | | | | | | | | | | | | | | | | | | | | 4 M4 cap screw x 20mm | | | | | | | | | | | | | 4| | | | | 1| | | | 5 M4 cap screw x 30mm | | | | | | | | | | | | | | 1| | | | | | | | 1 M4 cap screw x 45mm | | | | | | | | | | 4| | | | | | | | | | | | 4 M8 cap screw x 30mm | | | 1| | | | | | | | | | | | | | | | | | | 1 15 way D PCB mount plug | | | | | | | | | | | | | | | 1| | | | | | | 1 15 way D IDC socket | | | | | | | | | | | | | 1| | | | | | | | | 1 Fan 60mm x 15mm | | | | | | | | | | 1| | | | | | | | | | | | 1 Foam sponge 20mm x 20mm x 20mm | | | | 1| | | | | | | | | | | 1| | | | 1| | | 3 M3 grub screw x 6mm | | | | | | | | 1| | | | | | | | | | | | | | 1 Glass sheet 214mm x 202mm x 2mm | | | | | | 1| | | | | | | | | | | | | | | | 1 JHead MK5 hot end | | | | | | | | 4| | | | | | | | | | | | | | 4 Hex male / female pillar M3 x 20mm | | 3| | | | | | | | | | | | | | | | | | | | 3 M3 hex screw x 10mm | | | | | | | | | | | | | | 2| 4| | | | | | | 6 M3 hex screw x 16mm | | 2| | | | | | | | | | | | | | | | | | | | 2 M4 hex screw x 20mm | | 2| | | | | | | | | | | | | | | | | | | | 2 M4 hex screw x 50mm | | 1| | | | | | | | | | | | | | | | | | | | 1 M8 hex screw x 60mm, hobbed at 25 | | | | | | | | | 1| | | | | | | | | | | | | 1 IEC mains lead | | | | | | | | | | | | 3| | 2| 2| | 3| | | | | 10 LM8UU linear bearing | 1| | | | | | | | | | | | | | | | | | | | | 1 Melzi electronics | | | 1| | | | | | | | | | | | | | | | | | | 1 2 way Molex KK header | | | 1| | | | | | | | | | | | | | | | | | | 1 3 way Molex KK header | | | | 1| | | | | | | | | | | 1| | | | 1| | 2| 5 NEMA17 x 47.5mm stepper motor | | | | | | | | | | | | | | | | | | | | 2| | 2 Brass nut M8 | | 3| | 3| | | | | | | | 1| | | 1| | | | 1| | | 9 Nut M3 | | 2| | | | | | | | | | | | | | | | | | | | 2 Nut M4 | | 2| | | | | | | | | | | | | | | | | | | | 2 Nut M8 | | | | | | | | | | | | 4| | 2| 8| 4|16| | | 2|10| 46 Nyloc nut M3 4| | | | | | | | | | | | | 4| 1| | | | 1| | | | 10 Nyloc nut M4 | | | | | | | | | | 4| | | | | | | | | | | | 4 Nyloc nut M8 | | | | | | | | | | | | | | | 2| | | | | | | 2 Nitrile O-ring 2.5mm x 1.6mm | | | 1| | | | | | | | | | | | | | | | | | | 1 Extruder connection PCB | | | | | | | | | | 1| | | | | | | | | | | | 1 PLA sample 0.3mm ~20m | | | | | | | | | | | | | | | 1| | | | | | | 1 Polypropylene strip 402mm x 18mm x 0.5mm | | | | | | | | | | | | | | | 1| | | | | | | 1 Polypropylene strip 476mm x 25mm x 0.5mm | | | | | | | | 1| | | | | | | | | | | | | | 1 Polypropylene strip 271mm x 33mm x 0.5mm | | | | | | | | | 4| | | | | | | | | | | | | 4 M2.5 pan screw x 12mm | | | | | | | | | | | | | | | 3| | | | 4| | 8| 15 M3 pan screw x 8mm | | | | |28| | | | 4| 2| | | | | | | | | | 4| 4| 42 M4 pan screw x 12mm | | | | |11| | | | | | | | | | | 8| | 1| 4| | | 24 M4 pan screw x 16mm | | | | | | | | | 2| | | | | | | | | | | | | 2 6-32 pan screw x 9.5mm | | | | 2| | | | | | | | | | | 4| 2| | | | 2| | 10 No2 pan wood screw x 13mm | | | | | | | | | | | | | | | 1| | | | | | | 1 Ribbon cable 20 way 1240mm | | | | | | | | 1| | | | | | | | | | | | | | 1 Ribbon cable 26 way 381mm | | 1| | | | | | | | | | | | | | | | | | | | 1 Smooth rod 8mm x 22mm | | | | | | | | | | | | | | | | 1| | | | | | 1 Smooth rod 8mm x 271mm | | | | | | | | | | | | | | | | | | | | 2| | 2 Smooth rod 8mm x 340mm | | | | | | | | | | | 2| | | | | | | | | | | 2 Smooth rod 8mm x 385mm | | | | | | | | | | | | | | | | 1| | | | | | 1 Smooth rod 8mm x 418mm | 1| | | | | | | | | | | | | | | | | | | | | 1 Micro SD card | 1| | | | | | | | | | | | | | | | | | | | | 1 Micro SD to USB adapter | | | | | | | | | | | | | | | 1| 1| | | | 1| | 3 Microswitch | | 2| | | | | | | | | | | | | | | | | | | | 2 Spring 7mm OD, 1mm gauge x 10mm long | | | | | | | | | | | | | | | | | | | | 2| | 2 Threaded rod M8 x 275mm | | | | | | | | | 1| | | | | | | | | | | | | 1 Heatshrink sleeving ID 10mm x 15mm | | | | | | 2| | | | | | | | | | | | | | | | 2 PTFE sleeving OD 1.2mm ID 0.71mm x 62mm | | | | | | 2| | 2| | | | | | | | | | | | | | 4 Heatshrink sleeving ID 1.6mm x 15mm | | | | | | 2| | | | | | | | | | | | | | | | 2 PTFE sleeving OD 2.6mm ID 2mm x 45mm | 2| | | | | | | 2| 3| | | | | | 4| | | | | | | 11 Heatshrink sleeving ID 2.4mm x 15mm | | | | | | | | | 5| | | | | | | | | | | | | 5 Heatshrink sleeving ID 3.2mm x 15mm | | | | | | | | | | 1| | | | | | | | | | | | 1 PTFE tubing OD 4.6mm ID 3.84mm x 750mm | | | | | | | | | | | | | | | | | | | | | 2| 2 PVC aquarium tubing OD 6mm ID 4mm x 16mm | | | | | | | | | 2| | | | | | | | | | | | | 2 Heatshrink sleeving ID 6.4mm x 15mm | | | | | | | | 2| | | | | | | | | | | | | | 2 Heatshrink sleeving ID 6.4mm x 30mm | | | | | | 1| | | | | | | | | | | | | | | | 1 Heatshrink sleeving ID 6.4mm x 60mm | | | 2| | | | | | | | | | | | | | | | | | | 2 4 way terminal block | | | | | | | | 1| | | | | | | | | | | | | | 1 Epcos B57861S104F40 100K 1% thermistor | 1| | | | | | | | | | | | | | | | | | | | | 1 USB A to Mini B lead | | | | 2| | | | | | | | | | | 4| 2| | | | 2| | 10 Washer M2.5 x 5.9mm x 0.5mm | 4| 3| | 2| | | | 4| | | | 4| | 2|13| 4|22| | 4| 2|18| 82 Washer M3 x 7mm x 0.5mm 4| | 3| | |39| | | | 6| 2| | | 4| 2| | 8| | 5| 4| 4| 4| 85 Washer M4 x 9mm x 0.8mm | | | | | | | | | | | | | | 2| | | | 2| | | | 4 Washer M5 x 20mm x 1.4mm | | | | | | | | | | 8| | | | | | | | | | | | 8 Washer M8 x 17mm x 1.6mm | | | | | | | | | | 4| | | | | | | | | | | | 4 Washer M8 x 30mm x 1.5mm | | | | | | | | | | | 2| | | | | | | | | | | 2 Wingnut M4 | | | | | | 2| | | | | | | | | | | | | | | | 2 Red wire 16/0.2 length 170mm | | | | | | | | 1| | | | | | | | | | | | | | 1 Black wire 32/0.2 length 635mm | | | | | | | | 1| | | | | | | | | | | | | | 1 Red wire 32/0.2 length 620mm | 4| 6| | | | | | | | | | | | | 3| | | | 4| | 8| 25 Star washer M3 x 0.5mm | | | | |39| | | | 6| 2| | | | | | 8| | 1| 4| 4| 4| 68 Star washer M4 x 0.8mm | | 1| | | | | | | | | | | | | | | | | | | | 1 Star washer M8 x 1.6mm | | | | | | 1| | | 2| | | 3| | | | | 3| | | | | 9 Ziptie 100mm min length Printed: | | | | | | | | | 1| | | | | | | | | | | | | 1 atx_long_bracket.stl | | | | | | | | | 1| | | | | | | | | | | | | 1 atx_short_bracket.stl | | | | | 2| | | | | | | | | | | | | | | | | 2 cable_clip_AB.stl | | | | | 2| | | | | | | | | | | | | | | | | 2 cable_clip_AD.stl | | | | | 1| | | | | | | | | | | | | | | | | 1 cable_clip_CA.stl | | | | 1| | | | | | | | | | | | | | | | | | 1 d_motor_bracket.stl | | | | 1| | | | | | | | | | | | | | | | | | 1 d_motor_bracket_lid.stl | | | | | | | | | | | | | | | 1| | | | | | | 1 d_shell.stl | | | | | | | | | | | | | | | 1| | | | | | | 1 d_shell_lid.stl | | | | | | | | | | 1| | | | | | | | | | | | 1 dust_filter.stl 1| | | | | | | | | | | | | | | | | | | | | | 1 fan_guard.stl | | | | | | | | | | 1| | | | | | | | | | | | 1 feed_tube_connector.stl | | | | |10| | | | | | | | | | | | | | | | | 10 fixing_block.stl | 4| | | | | | | | | | | | | | | | | | | | | 4 pcb_spacer.stl | | | | | | | | | | | | | | | 1| | | | 1| | | 2 pulley.stl | | | | | | | | | | | | | | | 1| | | | | | | 1 ribbon_clamp_14_33.stl | | | | | | | | | | | | | | | 1| | | | | | | 1 ribbon_clamp_14_33NB.stl | | | | | | | | | | | | | | | 1| | | | | | | 1 ribbon_clamp_20_33.stl | | | | | 1| | | | | | | | | | | | | | | | | 1 ribbon_clamp_20_44.stl | | | | | | | | | | | | | | | | | 1| | | | | 1 ribbon_clamp_26_33.stl | | | | | | | | | | | | | | | | | 1| | | | | 1 ribbon_clamp_26_33N.stl | | | | | 1| | | | | | | | | | | | | | | | | 1 ribbon_clamp_26_44.stl | | | | | | | | | | 2| | | | | | | | | | | | 2 spool_bracket_female.stl | | | | | | | | | | 2| | | | | | | | | | | | 2 spool_bracket_male.stl | | 1| | | | | | | | | | | | | | | | | | | | 1 wades_big_gear.stl | | 1| | | | | | | | | | | | | | | | | | | | 1 wades_block.stl | | 1| | | | | | | | | | | | | | | | | | | | 1 wades_gear_spacer.stl | | 1| | | | | | | | | | | | | | | | | | | | 1 wades_idler_block.stl | | | | 1| | | | | | | | | | | | | | | | | | 1 wades_small_gear.stl | | | | | | | | | | | | 1| | | | | | | | | | 1 x_belt_clamp.stl | | | | | | | | | | | | 1| | | | | | | | | | 1 x_belt_grip.stl | | | | | | | | | | | | 1| | | | | | | | | | 1 x_belt_tensioner.stl | | | | | | | | | | | | 1| | | | | | | | | | 1 x_carriage.stl | | | | | | | | | | | | | 1| | | | | | | | | 1 x_carriage_fan_bracket.stl | | | | | | | | | | | | | 1| | | | | | | | | 1 x_carriage_fan_duct.stl | | | | | | | | | | | | | | 1| | | | | | | | 1 x_idler_bracket.stl | | | | | | | | | | | | | | | 1| | | | | | | 1 x_motor_bracket.stl | | | | | | | | | | | | | | | | 3| | | | | | 3 y_bar_clamp.stl | | | | | | | | | | | | | | | | 1| | | | | | 1 y_bar_clamp_switch.stl | | | | | | | | | | | | | | | | | 3| | | | | 3 y_bearing_mount.stl | | | | | | | | | | | | | | | | | 1| | | | | 1 y_belt_anchor.stl | | | | | | | | | | | | | | | | | 1| | | | | 1 y_belt_anchor_toothed.stl | | | | | | | | | | | | | | | | | 1| | | | | 1 y_belt_clip.stl | | | | | | | | | | | | | | | | | 1| | | | | 1 y_belt_clip_toothed.stl | | | | | | | | | | | | | | | | | | 1| | | | 1 y_idler_bracket.stl | | | | | | | | | | | | | | | | | | | 1| | | 1 y_motor_bracket.stl | | | | | | | | | | | | | | | | | | | | 2| | 2 z_bar_clamp.stl | | | | | | | | | | | | | | | | | | | | | 4| 4 z_coupling.stl | | | | | | | | | | | | | | | | | | | | | 1| 1 z_motor_bracket_lhs.stl | | | | | | | | | | | | | | | | | | | | | 1| 1 z_motor_bracket_rhs.stl | | | | | | | | | | | | | | | | | | | | 2| | 2 z_screw_pointer.stl Sub-assemblies: 1 bed_fan_assembly 1 electronics_assembly 1 extruder_assembly 1 extruder_connection_pcb_assembly 1 extruder_motor_assembly 1 frame_assembly 1 hot_end_assembly 1 machine_assembly 1 print_bed_assembly 1 psu_assembly 1 spool_holder_assembly 1 x_axis_assembly 1 x_carriage_assembly 1 x_carriage_fan_assembly 1 x_idler_assembly 1 x_motor_assembly 1 y_axis_assembly 1 y_carriage_assembly 1 y_idler_assembly 1 y_motor_assembly 1 z_axis_assembly 2 z_motor_assemblies
Re: TMI. RepRap circles. January 27, 2013 10:19PM |
So you cant actually do anything related to the goals of the "RepRap Movement". Instead you have to be a Software Engineer, Mechanical Engineer, an Electrical Engineer. And waste countless hours repeating work that has already been done.
Re: TMI. RepRap circles. January 28, 2013 03:53AM |
Re: TMI. RepRap circles. January 28, 2013 04:34AM |
Re: TMI. RepRap circles. January 28, 2013 10:49AM |
