Welcome!
Log In
Create A New Profile
Home
General
> Topic
Wire size for my Mendel Prusa
Posted by
scubi
Forum List
Message List
New Topic
scubi
February 02, 2013 05:49AM
Hi
Please can you tell me what wire spec I buy for the following :
1. Nema 17 motor
2. Heater Bed
3. Thermistor and Heat Resistor
Do it create a problem if the wire is incorrect ?
Thanks
Vaughan
Reply
nophead
Re: Wire size for my Mendel Prusa
February 02, 2013 06:30AM
Admin
I use 7/0.2 for motors.
32/0.2 for heated bed plus ribbon cable for the bit that needs to bend.
16/0.2 for hot ends.
If you use wire that is too thin it will get hot. For example if you used 7/0.2 for a heated bed it would catch fire.
www.hydraraptor.blogspot.com
Reply
scubi
February 02, 2013 08:31AM
Hi Nophead, thanks for the help.
The ribbon cable is that a standard cable that I can ask for or does it have special spec. My luck I have my first print and destroy everything with the wrong spec cables.
Thanks
Reply
nophead
February 02, 2013 10:39AM
Admin
Yes standard ribbon cable. I use 26 way for the bed. Two of those are the thermistor and then 12 for each of the bed connections.
Reply
Newer Topic
Older Topic
Print View
RSS
