Cure for The Common Curling: "The Brim" smileys with beer
Posted by Idolcrasher
Re: Cure for The Common Curling: "The Brim" smileys with beer
June 26, 2012 01:11PM
Greetings, this is just a heads-up to let you know that Slic3r 0.8.4 has native support for brim. smiling smiley
Okay, I should learn how to browse thread pages and avoid repeating myself. confused smiley
Edited 1 time(s). Last edit at 06/26/2012 01:12PM by Sound.
June 26, 2012 07:44PM
I did the openscad script! Looks like this has been on other peopls mind as well smiling smiley
June 26, 2012 07:46PM
@Sound
You did repeat yourself. A new version of Slic3r is out! Sweet!
It supports the Brim! Super Sweet!
June 30, 2012 09:20PM
here is the skeinforce module I changed today. Now you have a parameter "Brim Width". If you use it, change the gap over perimeter to 0.5
Just replace your old skirt.py by this one and enjoy. smiling smiley
open | download - skirt.py (15.5 KB)
June 30, 2012 11:27PM
first update winking smiley
open | download - skirt.py (15.6 KB)
July 01, 2012 04:53AM
"final" version. smiling smiley
Leaves original skirt function working. Just set Brim Width to a value > 0 if you want to use a brim.
open | download - skirt.py (16.9 KB)
July 06, 2012 05:52PM
Maybe it is better I assign a number to these versions. smiling smiley
July 09, 2012 02:02PM
Awesome!
Thanks Theodleif, brim action for our skeinforge friends smiling smiley
July 17, 2012 02:35PM
Ok, I got the Warping Test thingy done. Ran three tests and already the results are interesting. Halving the print speed had a clear effect, but much smaller than reducing the perimeters and fill density. Didn't have time to try this with a brim, though.
July 21, 2012 10:56PM
Very nice. I finally got this test piece to print with it. 10mm x 10mm x 50mm tower. It's a temperature calibration piece. That's the sixth attempt. The first five failed. Only two actually failed because of temperature. The other three disconnected from the print surface.
Edited 1 time(s). Last edit at 07/21/2012 10:58PM by MaFraL.
August 01, 2012 04:57PM
Another "Brim Victory" winking smiley
Nice
August 01, 2012 08:33PM
Yeah... there's a reason I didn't post that as an image. Is it just me or is almost all of it too big to fit the forum?
August 01, 2012 09:23PM
I wish the forum would resize images. You can still right-click on the image and view it by itself, that way your browser will resize it so it is all visible.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
August 02, 2012 03:45AM
To get them the right size I have to scale them to about 6" wide in photoshop.
August 02, 2012 11:21PM
Yeah, it is a little odd the pictures are not scaled properly.
I would love to help fund some kind of Professional Reconstruction of RepRap.org;
I would love to see a RepRap kickstarter/indie-gogo campaign whose goal is to raise funds for the purpose of helping build the RepRap Site and Community.
August 08, 2012 01:54AM
The brim used to make Rostock parts smiling smiley
October 27, 2012 04:04AM
Hello!
I change skirt.py for a better brim.
Brim starts from outer diameter downto internal. Its better.
New code for skirt.py:
For self.brimLine in xrange(self.repository.brimWidth.value-1, self.brimLine, -1):
October 29, 2012 08:14AM
Nice idea, this way if you are using the skirt to get sure the extruder is primed, you can use the brim instead.
Here's an updated skirt.py for people who don't want to bother doing the code modification themselves.
open | download - skirt_with_brim.py (16.9 KB)
October 29, 2012 05:11PM
If your still getting curling with a brim, use a longer brim! tongue sticking out smiley
October 29, 2012 08:03PM
Hahaha, usually true winking smiley
also, consider laying down blue painters tape
May 25, 2013 06:18AM
hi guys,
i'm using Skeinforge through SFACT and Repetier Host,
anyone knows if the new skirt.py with grim works in this set-up ?
i've tried it and i get an error message when slicing:
skirt.py, line 270, in getHorizontalXIntersectionstable
euclidean.addXIntersectionsFromLoopForTable(loop, horizontalXIntersectionsTable, self.edgewidth)
AttributeError: SkirtSkein instance has no attribute 'edgewidth'
maybe i'm using incompatible versions of SFCAT and/or SKeinforge ? If so , where do i see which version i'm using ?
thanks for your guidance
Edited 1 time(s). Last edit at 05/25/2013 06:23AM by Hugues.
May 26, 2013 05:07PM
Thanks for bringing this thread back. I've been trying to fight abs warping for the past few weeks. This worked a treat first time round.
May 27, 2013 04:13AM
Anyone tried printing a part around 180mm long?
March 07, 2015 11:37AM
thumbs up
Now I know how Brim works.
March 20, 2015 01:20PM
Attached is an update to the Brim feature. It is based on the most recent version posted by DeuxVis. It supports Brim Height (in layers) so that you can create a multi-layer brim (instead of just 1 layer high).
open | download - skirt.py (17.1 KB)
March 23, 2015 06:28PM
I print a 10mm Brim and position my parts so that I can use clamps to grab the edge. This is a little dicey because the clamps can interfear with the movement of the bed. Need to find some long nosed thin tweeser type clamps.
