Marlin Printrboard Z Motors fight when homing
Posted by mbcomputerservices
June 05, 2012 01:31AM
I have just completed assembling a reprap prusa (makrfarm linear bearing kit).
I have all axis' moving correctly and homing. However, when I home the z axis (using prontrface), the z motors seem to bind. They vibrate and shudder. When I manually help them to the end switch, they don't offer resistance, but they seem to be having some kind of feedback problem. Adjusting the current? pots next to the z Allegro driver has no effect on this issue.
When the axis reaches the switch, the motors behave perfectly. When I move them with prontrface, they perform flawlessly. Once I send a home command, I suffer my z motor problem.
Should I change the homing feed rate in the firmware? Any ideas to what? I have looked for documentation on this, but it is hard for the finding.
I look forward to being a part of this community, and contributing what I learn.
If the General board is too general for this question, please forgive my newness. My searches for this topic showed results in the general forum...
Edited 1 time(s). Last edit at 06/05/2012 01:34AM by mbcomputerservices.
Re: Marlin Printrboard Z Motors fight when homing
June 05, 2012 01:43AM
Using pronterface to move Z via the buttons find a good speed and use it to set the homing feedrate in Marlin.
June 05, 2012 12:47PM
I agree with Sublime, this is definitely a homing speed issue. Marlin's default Z homing speed is too high for your Z steppers and they are missing steps. Homing speeds are just below the Steps per Unit, I believe, but I don't have it in front of me.
June 05, 2012 02:59PM
Also, apply a little household machine oil to your Z rods and the Z nuts and cycle them up and down about 50mm to work it in a bit. A little lube really helps and reduces wear and tear on the Z rods especially the threaded ones.
If you want a faster Z axis, you can also change out the Z motors go give larger motors with more torque. Thankfully, the Z axis is the one where the speed of the motors has the least affect on the print time.
Check and make sure that the Z-Steps/mm are right on the Printrboard. You can either fix it in the firmware, or with a M92 command for your start code in your slicing software (put it BEFORE the G28 homing command).
June 05, 2012 03:46PM
Another successfully resolved issue!
I can see now that the motors are skipping steps.
I changed the z homing speed from 4*60 to 3*60, the z axis works great now. Thanks for the tips.
Beekeeper, I will check my steps/mm. Thanks for this important reminder.
June 05, 2012 06:15PM
M500 will save the current settings to EEPROM.
June 06, 2012 03:01AM
Andrew Smith: Thank you for the advice. I didn't think that the M500 worked.
December 18, 2020 01:36PM
;just a thought run a M119 command and see if all endstop sensors show Closed. I did not see that I had a cable caught between my hotend and the Z endstop sensor.
