Heated bed mounting position
Posted by Crux
June 10, 2013 04:20AM
Hi.
I am finishing to build my prusa i3.
I have a question: should the heated bed be mounted with the plate wired part on top.
check the picture:
Is this ok? Or should I put the wired part on bottom?
Thanks!
Re: Heated bed mounting position
June 10, 2013 04:59AM
thats fine, but the little glass bead (thermistor) should go through the hole in the middle.
June 15, 2013 09:57AM
thank you for the reply
so, it should go through the middle hole and put it between the glas and the heated bed?
June 15, 2013 03:57PM
The glass should lay flat on the heated bed. The thermistor is placed in the center hole. I use polyimide tape on the backside of the heated bed to keep itthe thermistor in position. If the thermistor is on the edge as in your pic it won't give an accurate temp reading for the center of the bed.
June 15, 2013 06:05PM
ok. thank you.
understood. I will do that tomorrow.
Thanks!
