PRUSA i3 / Hobbed bolt digging into filament
Posted by Emmanuel2011
June 27, 2013 12:05AM
Hello,
I just builded a Prusa i3 from makerfarm. The Hobbed bolt is digging into filament always at the same spot (please refer to the picture) ,
I tried without results:
1. Adjust the idler bearing at different settings
2. lower the tempeture of the hot end
3. lower the speed in slic3r from 30 to 15
No matter what i do The hobbed bolt always digg the filament in exactly the same place,
Can you guys give me your advice?
Warm Regards
Emmanuel
Re: PRUSA i3 / Hobbed bolt digging into filament
June 27, 2013 03:03AM
Looks like your nozzle is blocked
_______________________________________
Waitaki 3D Printer
June 27, 2013 07:12AM
that is an unusual amount of die swell on the end are you using 3mm feedstock or 1.75mm? it looks from the die swell that the hot end may be a 3mm? it looks like makerfarm only sells 3mm kits of this model.
June 27, 2013 08:59AM
> this model.
Yup, I'd guess 1.75mm Filament in a 3mm Hotend.
June 27, 2013 09:25AM
eye rolling smiley Well THAT CAN'T WORK!!!
eye popping smiley And you are right, that is exactly what the picture looks like.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
June 27, 2013 04:16PM
you guys are genius, I got a 0.35 mm nozzle. I check the filament i got and it says 1.75 mm in the spool. They sent me the wrong filament ,because i am such a newbie i did not double check.
Thank you, i just order new filament, i will keep you updated
Emmanuel
