endtops
Posted by printer_man58
endtops
June 28, 2013 11:32AM
Hi I am fairly new to using marlin software and my endstops don't seem to be working. I typed in the m119 command in pronterface to show my endstop details but it always show them open even after i pressed them. Here is my code
// Uncomment the following line to enable CoreXY kinematics
//#define COREXY
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine Enstop settings: Individual Pullups. will be ignored if ENDSTOPPULLUPS is defined
#define ENDSTOPPULLUP_XMAX
#define ENDSTOPPULLUP_YMAX
#define ENDSTOPPULLUP_ZMAX
#define ENDSTOPPULLUP_XMIN
#define ENDSTOPPULLUP_YMIN
//#define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Y_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Z_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
// Disable max endstops for compatibility with endstop checking routine
#if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS)
#endif
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
Thanks
Re: endtops
June 28, 2013 12:28PM
not knowing which board you using makes it tricky to suggest, but am using the ramps 1.3
and have the following lines set as:
const bool X_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
const bool Y_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
const bool Z_ENDSTOPS_INVERTING = false; // set to true to invert the logic of the endstops.
Re: endtops
June 28, 2013 01:29PM
Thanks for the help, but when I tried changing it to false something else happened. Now in pronterface it shows the endstops as triggered even though i haven't pressed anything. Any other help would be greatly appreciated.
Thanks
Re: endtops
June 28, 2013 01:36PM
find the bold bit in your marlin and delete // infront of it
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
Re: endtops
June 28, 2013 01:50PM
How are the Endstops wired to your board?
The switches need to be wired to Ground and Signal.
Re: endtops
June 28, 2013 03:53PM
Thanks alot shadowram and chris 33. could you also tell me where the signal and ground pins are to see if i put them correctly
Re: endtops
June 28, 2013 03:57PM
Even after I added that bit about disabling max endstops the code still shows them all triggered. This is what it looks like when i have only pressed the z axis endstop but not the other 2n
SENDING:M119
Reporting endstop status
x_min: TRIGGERED
y_min: TRIGGERED
z_min: TRIGGERED
Re: endtops
June 28, 2013 05:16PM
check my basic blog on endstops
up and running
Re: endtops
June 29, 2013 11:18AM
I saw your blog Chris33 and i saw how you placed the endstops and that is exactly how i put them on my board and it still wont show any difference if ive pressed the endstop or not,
Re: endtops
June 29, 2013 11:59AM
well then its your firmware this is my
// #define COREXY
// corse Endstop Settings
// fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined
#endif
#endif
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops true //If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true //If true, axis won't move to coordinates greater than the defined lengths below.
// Travel limits after homing
#define X_MAX_POS 200
#define X_MIN_POS 0
#define Y_MAX_POS 200
#define Y_MIN_POS 0
#define Z_MAX_POS 200
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
// The position of the homing switches
//#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used
//#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0)
//Manual homing switch locations:
#define MANUAL_X_HOME_POS 0
#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 0
up and running
Re: endtops
June 30, 2013 01:19PM
My firmware is the exact same except i think you are missing a lin which is right here
#endif
and when it is asking if you are using a direct drive or geared extruder which i am pretty sure i am using a geared extruder
