Extruder Gear Ratios for 1.75mm Filament
Posted by KDog
July 10, 2013 05:25PM
Hi All,
I recently purchased a Printrbot Jr. and was getting ready to print out some new extruder gears to replace wooden one but got to think a bit (a problem of mine). Printrbot recently switched to a 1.75mm hot end and some folks have had problems with it because the extruder was designed for 3.0mm filament. It is a fairly easy fix (a 1" piece of bowden tube takes care of it) but I've noticed that the extruder turns much faster than my 3mm filament printer, as it should, and the stepper gets pretty hot.
Would it be a good idea to change the gearing on the extruder closer to a 1 to 1 ratio like on direct drive models?
Cheers,
KDog
Re: Extruder Gear Ratios for 1.75mm Filament
July 10, 2013 08:17PM
I use direct drive on my extruders that use 1.75 and it works OK.
Rodney
Anonymous User
July 10, 2013 08:18PM
It wont help. Just adjust the current on your driver trimpot.
July 10, 2013 08:29PM
reduce current to motor. less torque is needed with 1.75mm feedstock anyway.
