So I know that my glass never gets near the temp of the heated bed because there is little thermal contact between them. You would not put a heat sync on a CPU without thermal grease for the same reason.
So I had some thermally conductive foam rubber (1/8" thick silicone foam) that I used in an old business. It's silicone and is a spongy soft so it conforms to any variation in contact. I just tried it and it's working as the top of the glass is not less than 9c different than the bottom of the heated PC board.
I am not sure if this will help prints as I am just now printing using it for the first time (had to re level the bed and such to accommodate the extra thickness) but so far it's printing great.
This may end up being something that is not a big deal (only time will tell) and it can be expensive, I used a used piece that I had laying around but a sheet may cost around $60 unless a lower priced product can be found.
It has a side benefit that it's spring like so may protect the head or bed if you accidentally drive the nozzle into the glass (been there done that).
Just curious if anybody has ever tried something like this, or if you think it may be a benefit?
Thanks!
