driver for Creatr August 07, 2013 03:25PM |
Re: driver for Creatr August 18, 2013 02:45PM |
(source)Quote
There are two different hardware versions of the Creatr's electronics.
Up to (estimated) February 2013 Leapfrog used a standard Arduino board with a RAMPS shield and separate stepper drivers. The new printers have a custom board developed for Leapfrog. This board not only has everything integrated on one PCB, it also uses different I/O signals.
If you have a Creatr with the new electronics, you need another version of firmware that contains the correct I/O assignments. Zabana published these changes in a reply on LinuxBozo's thread.
Please note that I do not have this new hardware so I cannot verify if this is as good as the original LinuxBozo firmware.
