Can Slic3r do backlash comp?
Posted by tjhj2
June 14, 2012 10:38AM
Hi all,
Can slicer do backlash compensation? If so where is the setting for it. I can't find it.
Thank you for your time and help.
Re: Can Slic3r do backlash comp?
June 14, 2012 11:55AM
No backlash compensation in slic3r.
If you're using belts for X and Y, you should be able to get Backlash low enough it doesn't matter.
April 25, 2013 02:42AM
so i have these little 28byj-48 steppers, they have backlash in the gearbox thats built in, is there a way to calibrate for this in any of the firmwares. the backlash is very consistant, when it changes directions the output just doesnt move for about 3 degrees, the same way each time.
April 25, 2013 02:58AM
Repetier-Firmware supports backlash compensation for x,y and z.
April 25, 2013 03:38AM
nice! im making a mini portable 3d printer and its using these cheap 28byj-48 motors, they have backlash and there is no way to get rid of it without making a new gearbox, and they cost 3 bucks each with a driver so pointless. now does repetier do delta bots or no?
edit: ah it does work with delta bots!
second question, what arduinos will it run on, mega due uno?
Edited 1 time(s). Last edit at 04/25/2013 03:44AM by aduy.
April 25, 2013 04:03AM
Yes, delta support is available.
> mega due uno?
A mega is good as it needs the ram. Due support will come but will take some time. Uno has not enough ram for the firmware.
May 24, 2013 03:26PM
aduy Wrote:
> I'm making a mini portable 3D printer and it's using these cheap 28byj-48 motors.
Do you have a thread for your mini portable 3D printer using those 28BYJ-48 motors? I'm trying to think about a mechanical way of tensioning the belt/cable to eliminate the backlash.
woo
May 25, 2013 02:04AM
why not use fishing line?
about backlash compensation, those steppers have all plastic tiny gears, and my personal opinion is they wont last long, those gears will worn out very fast, specially in reprap conditions, where prints lasts few hours.
i suggest smaller nema 17 or nema 11 stepper.
i'm hoping that i am wrong smiling smiley
good luck smiling smiley
May 25, 2013 07:01AM
I plan on using fishing line. and we are looking into other motors.
