Help with TERRIBLE print quality December 23, 2013 05:40PM |
Re: Help with TERRIBLE print quality December 23, 2013 06:07PM |
Re: Help with TERRIBLE print quality December 23, 2013 06:25PM |
Re: Help with TERRIBLE print quality December 23, 2013 07:25PM |
Re: Help with TERRIBLE print quality December 24, 2013 02:04AM |
iquizzle
Ah ok. Now I think we're getting somewhere.
You should always measure the filament as it is extruded to get that number exactly correct. Here is what you do:
1. Leave that number as-is.
2. Take a permanent marker and make a dot on your filament a couple inches away from the extruder.
3. Measure exactly how far that mark is from the top of the extruder.
4. Open pronterface and extrude 20mm of filament.
5. Measure the distance of your mark from the top of the extruder again.
Your mark should have moved 20mm. If it moved 15mm for instance, then take your steps_per_unit for the extruder and multiply by 20/15 (or 20 divided by whatever you measured).
Then you can take that scaled number and put it into your steps_per_unit and try again. If you repeat this process once or twice, you should be getting accurate extrusions.
It's been a while since I've done this, so someone correct me if I missed something.
Re: Help with TERRIBLE print quality December 25, 2013 06:55PM |
