Difference z-home and z-up March 10, 2014 09:24PM |
Re: Difference z-home and z-up March 11, 2014 04:24AM |
Re: Difference z-home and z-up March 11, 2014 08:40AM |
Re: Difference z-home and z-up March 11, 2014 08:43AM |
sungod3k
Hi guys and girls,
Recently i did some changes to me z axis and recalibrated afterwards. Im unsing sprinter + pronterface. When I give the command to move the z axis up everything works fine and smooth but when I give the z home command the motor starts stalling and eventually blocks completely. Even when I disconnect the coupler and have the motor running freely I hear it skipping steps.
Also when the z up command hits the entstop the it just stops and doesnt the little "hit endstop, down a bit, up a bit routine"
If this behavior would show on all movements I would conclude a bad stepper driver ( I got the same behavior with a different motor) but it working normally when giving one command but not with the other seems weird.
So my question is first of all "why" and 2nd is there a firmware difference between z home and z up?
Re: Difference z-home and z-up March 11, 2014 09:02AM |
Re: Difference z-home and z-up March 11, 2014 09:42AM |
Re: Difference z-home and z-up March 11, 2014 10:19AM |
sungod3k
There is definitely less power when I home z i can easily stop the motor with one hand.
I just switched the steppers drivers, the axis and the motors and it doesnt matter what driver or motor I use the weird behavior show only when I home z. Which would indicate a firmware issue.
Re: Difference z-home and z-up March 11, 2014 05:06PM |
