Re: Extruder performance - can it be measured? June 28, 2012 10:12AM |
Re: Extruder performance - can it be measured? June 28, 2012 01:32PM |
Re: Extruder performance - can it be measured? June 28, 2012 04:45PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Extruder performance - can it be measured? July 01, 2012 01:32PM |
Re: Extruder performance - can it be measured? July 01, 2012 03:27PM |
Re: Extruder performance - @150mm/s July 01, 2012 08:32PM |
Re: Extruder performance - can it be measured? July 02, 2012 05:08AM |
Re: Extruder performance - can it be measured? July 02, 2012 03:38PM |
Re: Extruder performance - can it be measured? July 02, 2012 06:17PM |
Re: Extruder performance - can it be measured? July 03, 2012 02:17PM |
Re: Extruder performance - can it be measured? July 03, 2012 08:00PM |
Re: Extruder performance - can it be measured? July 04, 2012 05:04PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Extruder performance - can it be measured? July 04, 2012 07:09PM |
There is absolutely no reason to attempt to print fast if you are getting those results.
Re: Extruder performance - can it be measured? July 04, 2012 07:21PM |
Re: Extruder performance - can it be measured? July 04, 2012 07:43PM |
Re: Extruder performance - can it be measured? July 04, 2012 08:16PM |
Re: Extruder performance - can it be measured? July 04, 2012 08:43PM |
Re: Extruder performance - can it be measured? July 05, 2012 06:55AM |
Extruder name [DIY, other] 2 Test conditions 2.1 Filament 2.1.1 Material [PLA, ABS, other] 2.1.2 Filament average diameter mm 2.1.3 Die swell (mid air extrusion diameter) mm 2.2 Thermal 2.2.1 Melt zone temperature °C 2.2.2 Temperature fluctuation % 2.2.3 Ambient temperature °C 2.2.4 Ambient humidity % 2.3 Mechanical 2.3.1 X,Y,Z acceleration mm/s^2 2.4 Nozzle data 2.4.1 Nozzle orifice diameter mm 2.4.2 Nozzle orifice length mm
Re: Extruder performance - can it be measured? July 05, 2012 12:24PM |
Re: Extruder performance - can it be measured? July 05, 2012 06:22PM |
Re: Extruder performance - can it be measured? July 05, 2012 06:42PM |
Re: Extruder performance - can it be measured? July 05, 2012 07:36PM |
Re: Extruder performance - can it be measured? July 12, 2012 09:29AM |
Re: Extruder performance - can it be measured? July 14, 2012 01:52PM |
Re: Extruder performance - can it be measured? July 15, 2012 05:05PM |
Re: Extruder performance - can it be measured? July 15, 2012 09:31PM |
Re: Extruder performance - can it be measured? July 16, 2012 03:44AM |
Re: Extruder performance - can it be measured? July 16, 2012 11:57AM |
Re: Extruder performance - can it be measured? July 16, 2012 03:30PM |
Re: Extruder performance - can it be measured? July 16, 2012 04:08PM |
