My project of a truly universal extruder July 01, 2014 08:52AM |
Re: My project of a truly universal extruder July 04, 2014 09:23AM |
Re: My project of a truly universal extruder July 04, 2014 10:45AM |
Re: My project of a truly universal extruder July 14, 2014 01:01PM |
Re: My project of a truly universal extruder July 14, 2014 02:59PM |
Re: My project of a truly universal extruder July 14, 2014 03:02PM |
Re: My project of a truly universal extruder July 14, 2014 03:14PM |
Re: My project of a truly universal extruder July 14, 2014 03:28PM |
lucaslucas80
Since I still consider myself new to this 3d printing world, I don't have much knowledge of hotend models and their respective mounts, that's why I usually call this extruder "universal" with the quotation marks.
I'm used to the all-metal hotends where you usually insert the thermistor into a small socket near the nozzle, so it's easy to leave the wiring far from the mount...
I have never used a j-head, although I know the model, but had no idea about these soldered thermistors. That may really be a problem...
Also, I have never built a delta, all I know is that the extruder carriage is quite different than in a prusa.
So yeah, this extruder might not be as universal as I expected...
Re: My project of a truly universal extruder July 14, 2014 03:32PM |
Re: My project of a truly universal extruder July 14, 2014 04:57PM |
tjb1
Well this would not fit a delta as they are almost all bowden tubes due to the design and they can't handle much weight...
Re: My project of a truly universal extruder July 15, 2014 07:53AM |
KingRahl
tjb1
On the contrary. The Delta has a setup nearly the same as this already.
While you wouldn't use the extruder part directly with the hot end, you can copy the male and female ends to put on either side of the Bowden connections.
