The more flexible the filament the less suitable it is, so things like Ninjaflex should be avoided. More retraction is needed with a Bowden so the print time is also increased trivially. Other than those, a Bowden setup can be pretty close to perfection.
Quote leadinglights
I got surprisingly good results with 1.75mm Ninjaflex and a 40cm Bowden setup. Stringing is an issue though.
