Importing Assemblies / Support Structures into Slic3r? March 19, 2015 10:31PM |
Re: Importing Assemblies / Support Structures into Slic3r? March 20, 2015 05:27AM |
Re: Importing Assemblies / Support Structures into Slic3r? March 20, 2015 06:53AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Importing Assemblies / Support Structures into Slic3r? March 20, 2015 10:58AM |
skynetprinter
Support structures? Slicer can support an entire model which is practical for building any shape
slic3r -m model.stl --load model_config.ini support.stl --load support_config.ini
Re: Importing Assemblies / Support Structures into Slic3r? March 20, 2015 11:33AM |
Re: Importing Assemblies / Support Structures into Slic3r? March 20, 2015 06:08PM |
Re: Importing Assemblies / Support Structures into Slic3r? March 20, 2015 10:02PM |
richokarl
It should be possible to do what you are trying to do in slic3r. From your original post I belive you have 2 or more STL,s one the main object and the others your self created support structures.
It sounds like from your description you are using the add button in slicer to load the STL files and slicer is auto arranging them on the build platform rather than overlaying them, this is because slic3r thinks they are separate objects. To get them to load as you want them to, add the first stl as normal then click on it and click the settings button in the top bar. This will open a new window, you will see two buttons here load part and load modifier. Click load part and pick your second stl it should now look as you want with the two parts overlayed. Slicer will still not know which of the two objects you want to be support. But you can modify each object in this screen to use whatever extruder etc... You like so just specify the extruder infill type etc on the obj you want to be used as your support.
