Hello again all.
This Skeinforge is giving me headache because of the speeds.
I'm printing a calibration part and the 2 first layers print at normal speed, but from the third layer and above the speed decreses.
I'm using this settings:
Feed Rate (50 mm/s)
Flow Rate (50)
Object first layer FEED Rate infill multiplyer : (0.4)
Object first layer FEED Rate perimeter multiplayer (0.4)
Object first layer FLOW Rate infill multiplyer : (0.4)
Object first layer FLOW Rate perimeter multiplayer (0.4)
Orbital feed rate over operating feed rate (1)
Maximum Z feed rate (1)
Perimeter feed rate multiplier (1.0)
Perimeter flow rate multiplier (1.0)
Travel Feed rate (150 mm/s)
The same part sliced with Slic3r 0.8.4 runs much faster than this. In Skeinforge, when loaded into pronterface it says will take 1 hour 22 minutes and in Slic3r it says 33 minutes.
What am I missing here?
Thank you
Ernesto Pareja
dcctrains.netne.net
