Any tips and tricks for threading?
Posted by Ollie
July 15, 2012 05:02PM
Hey guys,
Once again I've sorta run into another project of mine where precision is important. So I've decided it's time to start using my tools properly, but searching around, there's no real tips on getting a good, straight thread using a die. Loads for taps tho..
I'm trying to thread a ~6mm long, 10mm thread into some mild steel, unfortunately, because of the parts odd shape I can't fit it into my lathe and I don't have a pillar drill to rest the die on. So I'm lost for ideas.
Hopefully most of you have had more experience with this type of thing than me,
Ollie.
VDX
Re: Any tips and tricks for threading?
July 16, 2012 07:40AM
... think how goldsmiths fit their 'misshaped' parts to drill precise bores and such - maybe you can embed your part in a cylindrical mould filled with hardening 2K resin, so it's usable in the lathe?
Viktor
July 16, 2012 05:05PM
Odd shaped or thin walled parts often get a fixture cast around them to enable clamping and properly support the piece. There are low-temp, usually reusable metal alloys called fixturing alloys specifically for this purpose. Plastic or plaster might be usable for you for this purpose as well.
Presuming the shaft you wish to thread is clampable, fixture the other side of the piece and turn it concentric by clamping the shaft. Then reverse the piece and thread the shaft as normal on your lathe, either cutting the thread or using the tailstock to suuport and align your die to the workpiece in the headstock.
July 16, 2012 05:47PM
Hey VDX and Circuits,
I hadn't actually thought of casting a fixing round the part in question. It's only a prototype, so I wasn't going to spend a lot on it, as ive already change the design for 2.0, so i'd've thought an alloy or resin would be a bit much for this first part.
However, I see how plaster would be a cheap and easy casting, but has it been tried in a chuck? Surely it would crack after clamping?
I had another thought too, would some sort of tape wrapped round the part suffice? Or would the jaws just sink too far into the tape?
Ollie.
July 16, 2012 06:02PM
Plaster is probably too brittle to clamp mild steel for this purpose. I have low temp moldable plastic (brand name instamorph) and fixturing alloy on hand I'd be using. Given the part is metal, some resin should work for you, then simply heat the part to burn or slough it off when done. I doubt you'll be able to get tape concentric enough for good threads, though.
July 16, 2012 06:14PM
Use a 4 jaw and an indicator? I got both lyin round
July 16, 2012 06:16PM
Hello,
Could you post a picture of the part in question?
Regards,
Brian
Ollie Wrote:
> Hey guys,
> taps tho..
> I'm lost for ideas.
> Ollie.
July 16, 2012 06:42PM
Hey Brian,
Not tonight unfortunately, not near my scanner or a camera atm, in the morning I can but until then lemme see if I can describe it to u.
It's basically a 5cm long cylinder, with each end having a larger diameter than the middle. The end I need to thread is 10mm Dia. And is 6mm long, all of that needs to be threaded correctly with 10mm x1mm pitch, 60 degree thread. There is a hole running though the length of the part with a Dia. Of 5mm, the middle length of the part is say, 35mm long, Dia 7mm, then the bottom is ~10mm long with Dia. 8mm.
Sorry if that's confusing, but best I could do right now.
Ollie.
July 16, 2012 07:04PM
Hello,
Ok, I think I get a picture of what it looks like. It sounds like a great candidate for a lathe. Why won't it fit in your lathe?
Regards,
Brian
Ollie Wrote:
> Hey Brian,
> Dia. 8mm.
> right now.
> Ollie.
July 16, 2012 07:14PM
Because my jaws are frankly too long to get a decent, full length grip on the part, because of the ends being later than the middle. So I'm not too sure how I could chuck the part.
Ollie.
July 16, 2012 07:43PM
try putting the part into a chuck centre and putting the die and rack against the jaws and turn the die as you advance the chuck.
that;s how we were taught in tradeschool.
July 16, 2012 07:47PM
Mount it between centers, on the lathe, then thread it.
Regards,
Brian
July 16, 2012 07:54PM
For anything bigger than the part I'm workin on Brian, I'd agree with yu, but the walls are too thin in my opinion for between centers. Although Mech has a good point, cheers, I'll give it a go smiling smiley
Ollie.
July 16, 2012 08:28PM
Hello,
If the walls are too thin, maybe the center should have been drilled out last, after all of the high-stress machining operations are finished?
Regards,
Brian
> smiling smiley
> Ollie.
July 17, 2012 01:53AM
Probably, yeah. But I rush into things....
Ollie.
