CAL extruder stepper motor type
Posted by tikkis
April 21, 2015 07:15PM
hello. i man calibrating my sunhokey prusa i3 etruder. and wonder what type of stepper motor this is?
could some one help me with the math?
i measured out 150mm and extruded 100mm. (G1 E100 F90 at temp 215C)
the fillment has was left is 74. 150-74=76mm extruded filament-.
in the display in the purse i3. i have
Amax E: 10000
Esteps/mm: +0080.5
Thank you for any reply
open | download - IMG_0413.JPG (287.1 KB)
Re: CAL extruder stepper motor type
April 21, 2015 10:32PM
The stepper doesnt determine the extrusion length. If you need to calibrate google "triffid hunter calibration guide".
April 22, 2015 08:01AM
Divide 80.5 (step/mm) by 76 (distance extruded)
Multiply result by 100 (distance required)
So Esteps/mm wants to be 106. or 105.92. Try that number and repeat to double check/ fine tune
It is easier and quicker to do this calibration without the hotend attached and just wind out the filament into free air.
Your stepper is a YH42BYGH47-401A Nema_17_Stepping_Motor
a
