Need help setting up Pronterface in Ubuntu October 23, 2014 03:02PM |
pronterface.py
jim@Ilias:~/Printrun$ ./pronterface.py
WARNING:root:Memory-efficient GCoder implementation unavailable: No module named gcoder_line
[WARNING] Could not setup DBus for sleep inhibition: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.ScreenSaver was not provided by any .service files
Traceback (most recent call last):
File "./pronterface.py", line 32, in from printrun.pronterface import PronterApp
File "/home/jim/Printrun/printrun/pronterface.py", line 32, in from . import pronsole
File "/home/jim/Printrun/printrun/pronsole.py", line 42, in from .power import powerset_print_start, powerset_print_stop
File "/home/jim/Printrun/printrun/power/__init__.py", line 90, in orig_nice = p.get_nice()
AttributeError: 'Process' object has no attribute 'get_nice'
Re: Need help setting up Pronterface in Ubuntu October 23, 2014 11:14PM |
Re: Need help setting up Pronterface in Ubuntu October 24, 2014 01:23PM |
configure: error:
Package requirements
(gtk+-2.0 >= 2.18
glib-2.0 >= 2.26
gio-2.0 >= 2.26
indicator-0.4 >= 0.4.93
dbusmenu-gtk-0.4 >= 0.5.90) were not met:
No package 'gtk+-2.0' found
No package 'glib-2.0' found
No package 'gio-2.0' found
No package 'indicator-0.4' found
No package 'dbusmenu-gtk-0.4' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you installed software in a non-standard prefix. Alternatively, you may set the environment variables LIBRARY_CFLAGS and LIBRARY_LIBS to avoid the need to call pkg-config. See the pkg-config man page for more details.
Re: Need help setting up Pronterface in Ubuntu October 24, 2014 02:47PM |
cd printrun jim@Ilias:~/Printrun/printrun$ ./pronterface.py
bash: ./pronterface.py: Permission denied
jim@Ilias:~/Printrun$ cd printrun
jim@Ilias:~/Printrun/printrun$ sudo bash -c ./pronterface.py
Re: Need help setting up Pronterface in Ubuntu October 24, 2014 10:21PM |
Re: Need help setting up Pronterface in Ubuntu October 25, 2014 07:16AM |
chmod 755 ./pronterface.py # needed only once ./pronterface.pyor
python ./pronterface.py
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Need help setting up Pronterface in Ubuntu October 25, 2014 09:05AM |
I have searched this valueError online but it seems to be to complicated for a novice like me...Quote
jim@Ilias:~/Printrun/printrun$ chmod 755 ./pronterface.py
ValueError: Attempted relative import in non-package
Re: Need help setting up Pronterface in Ubuntu October 25, 2014 07:02PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 11:14AM |
jim@Ilias:~/Printrun$ chmod 755 ./pronterface.py
WARNING:root:Memory-efficient GCoder implementation unavailable: No module named gcoder_line [WARNING] Could not setup DBus for sleep inhibition: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.ScreenSaver was not provided by any .service files
AttributeError: 'Process' object has no attribute 'get_nice' jim@Ilias:~/Printrun$
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 11:31AM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 12:08PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 12:39PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 01:32PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 01:34PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 02:25PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 02:46PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 03:00PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 03:46PM |
swe3tdave@server:~$ pronterface.py Traceback (most recent call last): File "/usr/bin/pronterface.py", line 32, in from printrun.pronterface import PronterApp ImportError: No module named printrun.pronterface
sudo apt-get install python-serial python-wxgtk2.8 python-pyglet python-tornado python-setuptools python-libxml2 python-gobject avahi-daemon libavahi-compat-libdnssd1 python-dbus python-psutil git git clone https://github.com/kliment/Printrun.git
sudo apt-get update
sudo apt-get upgrade
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 03:59PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 04:12PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 06:21PM |
I did not do the upgrade.Quote
jim@Ilias:~$ sudo apt-get install pronterface
Reading package lists...
Done Building dependency tree
Reading state information... Done
E: Unable to locate package pronterface
since I want to stay on 12.04 non pae
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 06:40PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 07:16PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 07:36PM |
Re: Need help setting up Pronterface in Ubuntu October 26, 2014 10:59PM |
Re: Need help setting up Pronterface in Ubuntu October 27, 2014 05:13AM |
Mendel90
I lost a few discs and decided to burn a new version wich told me right away about the PAE being non present.
Re: Need help setting up Pronterface in Ubuntu October 27, 2014 07:01AM |
Re: Need help setting up Pronterface in Ubuntu October 27, 2014 08:29AM |
Re: Need help setting up Pronterface in Ubuntu October 29, 2014 02:22PM |
Re: Need help setting up Pronterface in Ubuntu October 29, 2014 04:46PM |
