Replicator Electrocutes Me April 24, 2015 05:58PM |
Re: Replicator Electrocutes Me April 24, 2015 06:30PM |
Re: Replicator Electrocutes Me April 24, 2015 06:46PM |
Re: Replicator Electrocutes Me April 25, 2015 03:53PM |
Re: Replicator Electrocutes Me April 25, 2015 05:52PM |
Re: Replicator Electrocutes Me April 27, 2015 09:23AM |
Electricity wants to find the path to ground with the least resistance. With a ungrounded or poorly grounded outlet, you were that path. With a outlet with a better ground, it could use that. The outlet is doing it's job, but it's putting a band-aid on the problem. The real problem is that your power supply is leaking current and that shouldn't happen. Fix or replace the power supply before something bad happens.Quote
jessicabrenner
HOLY CRAP, I just disconnected the power supply from the printer to inspect the connection. Upon touching the outer metal plate of the DIN connector (which is supposed to be ground probably), I get zapped!!!! So I moved to a new outlet (one that doesn't look like it was built in the 1800s), and I don't get zapped. So the problem was that I was using a super old outlet that is not grounded properly. I hope that wasn't constantly consuming current and increasing my electric bill!
Re: Replicator Electrocutes Me May 01, 2015 11:48PM |
