Can MKS 1.2 base board take 24v? April 07, 2015 09:27PM |
Re: Can MKS 1.2 base board take 24v? April 07, 2015 10:55PM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Can MKS 1.2 base board take 24v? April 08, 2015 07:55AM |
Re: Can MKS 1.2 base board take 24v? April 08, 2015 09:05AM |
Yes, tie the two grounds together. They'll share the same ground plane.Quote
skynetprinter
So to recap, i keep the board wired the same, then i fix in the 24v GND wire along side the 12v GND input on the board,
Yep.Quote
and i change the heatbed input to 24V with a fuse on it.
Any type of blade-style fuse will be fine if that's what you mean by "motorbike fuse". It should be rated for the maximum amount of current your board will use, plus a bit more. Measure the resistance of your board when it's wired for 24v operation. Divide 24V by that resistance and you'll get it's current draw. Most 200x200mm beds will draw 10-12 amps at 12 volts, and 5-6 volts at 24 volts...doubling the voltage halves the current in order to keep the same overall power output. So something like a 7.5 amp fuse should work unless your bed is out of spec.Quote
Will a motorbike fuse be OK? What amperage should the fuse be rated for?
Re: Can MKS 1.2 base board take 24v? April 19, 2015 10:54AM |
Re: Can MKS 1.2 base board take 24v? April 28, 2015 05:27AM |
Re: Can MKS 1.2 base board take 24v? April 28, 2015 06:44AM |
skynetprinter
It's taking 25 minutes to get to 110 degrees with insulation on top, and then when i take the insulation off it goes back to 105 degrees.
Can i put 36v onto the 24 heatbed input using the 24 and 12v lines in series?
Re: Can MKS 1.2 base board take 24v? May 12, 2015 12:47AM |
