PRINT WOOD May 22, 2015 09:57AM |
Re: PRINT WOOD May 22, 2015 10:16AM |
Re: PRINT WOOD May 22, 2015 11:09AM |
Re: PRINT WOOD May 22, 2015 11:31AM |
Re: PRINT WOOD May 22, 2015 01:18PM |
ggherbaz
Well I don't use Repetier but Simplify3d and with it you just set multiple processes with different temperatures at different layer heights. But if your printer have a display, you can manually change the temperature as the part is printed.
I have printed with wood, but have not changed the temperature instead I use a little butane torch to create effects in the outer layer.
Re: PRINT WOOD May 22, 2015 01:45PM |
Re: PRINT WOOD May 22, 2015 02:01PM |
Re: PRINT WOOD May 22, 2015 02:07PM |
Re: PRINT WOOD May 22, 2015 02:23PM |
Re: PRINT WOOD May 22, 2015 02:28PM |
Re: PRINT WOOD May 22, 2015 02:43PM |
Re: PRINT WOOD May 22, 2015 07:46PM |
Re: PRINT WOOD May 22, 2015 10:16PM |
Re: PRINT WOOD May 23, 2015 04:19AM |
Re: PRINT WOOD May 25, 2015 01:54PM |
Ralphy
DANG IT
Re: PRINT WOOD May 25, 2015 04:44PM |
Re: PRINT WOOD May 30, 2015 12:18PM |
JonS
Ralphy
DANG IT
I just saw that ColorFabb has a 30% wood filament with finer particles. While their own site says very little about it, other places claim it'll work with a 0.4mm nozzle.
However, they also say that it doesn't change color with temperature, so banding effects aren't achievable.
ColorFabb Woodfill Fine
Re: PRINT WOOD May 30, 2015 10:14PM |
Re: PRINT WOOD June 02, 2015 03:45PM |
Re: PRINT WOOD June 05, 2015 12:04AM |
Re: PRINT WOOD June 05, 2015 02:05AM |
Re: PRINT WOOD June 05, 2015 11:06AM |
GRAYWOLF
Do you know about the "Wood" plugin for cura?
http://wiki.ultimaker.com/CuraPlugin:_Wood
