capacitive or inductive proximity
Posted by fikri
July 10, 2015 03:56AM
halo.
I want to ask which is better capacitive or inductive proximity for use in the auto leveling bed?
Re: capacitive or inductive proximity
July 10, 2015 04:34AM
I went through them all: IR, modulated IR, ultrasonic, capacitive, inductive, and finally differential modulated IR. Capacitive and inductive can both be made to work quite well if you print on a metal bed, although capacitive tends to be sensitive to temperature and humidity. If you use a glass bed, then many inductive sensors won't work at all unless you have a steel plate under the glass. Capacitive sensors are still usable with a glass bed, subject to temperature and moisture sensitivity. Also if you use interchangeable glass beds as I do, they need to have exactly the same thickness and surface coating if any, otherwise the height will depend on which glass bed you use.
Remember that the low cost proximity sensors you can buy are intended to detect if an object is there or not, not to provide a stable distance reference reprodicible to a few hundredths of a mm.
I settled on differential modulated IR because it provides a height reference from the top surface of the glass and works with most print surfaces, with the caveat that when used with plain glass, it doesn't like a strongly reflecting surface under the glass. I am about to put these sensors into mass production. See [forums.reprap.org] for more.
July 10, 2015 06:58PM
may for the time being I would choose to use inductive proximity, because it is not affected by temperature and humidity conditions. it would be better to save costs in making my first 3D printer.
I want to ask again. What if I use the bed only aluminum plate without giving heat-resistant masking tape. if it does nothing when printing?
July 12, 2015 09:36PM
[www.amazon.com]
i use this one, consistent with heat and moisture (live in FL) and it runs on 5v so no weird stepdown voltage divider sass
July 12, 2015 10:49PM
hi greggo.
Which sensor is your favorite. capastive proximity, inductive or infrared?
July 14, 2015 02:34AM
neither, i find using a dial indicator and manually leveling the bed just better.
