Weird question I think but I Googled...
Posted by Dark Alchemist
July 21, 2012 05:24AM
and I could not find the answer.
How many feet/meters in a pound/kg of 1.75mm and 3mm filament of the various kinds?
Re: Weird question I think but I Googled...
July 21, 2012 06:36AM
There is an online calculator somewhere I have forgotten but it is easy to calculate from the density of the plastic, which can be Googled.
July 21, 2012 06:37AM
for 3mm its approx 90 meters per kg but depends a little on the filament.
you can calculate it fairly easy tho
calculate the volume of the filament per meter and multiply it by density of PLA or ABS that will give you a weight per meter
July 21, 2012 07:01AM
Lost me.
Density for PLA is 1.23 - 1.25 g/cm³ and the volume is what?
[www.quabbin.com]
[www.timbercon.com]
The problem is that none give you the dimensions of the spools. :/
Edited 1 time(s). Last edit at 07/21/2012 07:06AM by Dark Alchemist.
July 21, 2012 07:10AM
You can use the equation:
Volume = mass / density
Also understanding that
Volume = Area x Length
The equation becomes:
Length = mass / ( density x pi x ( diameter / 2 )^2 )
This only gives you a very rough theoretical guide, the actual products will vary. Also note that density is in kg/m^3, Volume is in m^3, diameter is in metres, and mass is kg
Edited 1 time(s). Last edit at 07/21/2012 07:13AM by MacAleJam.
July 21, 2012 07:15AM
Yeah, cool beans cause all of the formulas I found the missing part of the equation is how many wraps per layer and how many layers. Ahem, isn't that easily figured via math? [www.ehow.com] that link made my head swim.
Hmmmm, could you check this formula? 1kg 3D Printer PLA Filament 3mm. PLA is 1240 kg/m3 diameter of the filament is .003m mass is 1kg pi is 3.1415926535897 and I came up with 0.02928701
Edited 1 time(s). Last edit at 07/21/2012 07:44AM by Dark Alchemist.
July 21, 2012 12:58PM
i get 114meters
but you have to take in account that every spool is different. Al manufactures say they get 3.0 +-0.1 mm so a spool diameter maybe 3.1 or 2.9 then you get a length between 122.1 m and 106.8 m
Edited 1 time(s). Last edit at 07/21/2012 01:04PM by Weedz.
July 21, 2012 02:06PM
With:
mass = 1kg
Diameter = 0.003 m
Density = 1240 kg / m^3
The formula would become Length = 1 kg / ( 1240kgm^-3 * 3.14159265 * ( 0.003m / 2 )^2 ) = 114.0895649404 metres, as Weedz has pointed out.
For Coils around Spool
The Figure below shows a cross section of a spool with some filament wrapped around it (represented by blue circles).
Reel Cross Section by MacAleJam, on Flickr
For demonstration purposes assume that:
  • HSPOOL = Spool wrapping height = 0.05 metres
  • WCORE = Diameter of the core (what the filament wraps on to) = 0.01 metres
  • WOUTER = Size of the flanges = 0.05 metres
  • DFIL = Diameter of filament = 0.003 metres
Finding The Number of Coils
We know the length of tube we have to wrap the filament around, HSPOOL, and we know the diameter of the filament, DFIL, so it is possible to work out the number of times the filament can lay side by side along the length of tube using:
NLOOPS = HSPOOL / DFIL
For this example that would be NLOOPS = 0.05 / 0.003 = 16 times (roughly). As HSPOOL should not change as you add more layers the number of coils (or loops dependant on what you would rather call a revolution of filament) should stay the same on each layer.
Finding the Length of the First Layer
Now that we know the number of coils it is possible to find the length of filament used to create the first layer of coils. To do this the distance travelled by the filament for one coil must be found -- and it can as one coil of filament roughly follows the circumference of the core. Hence the length of one coil can be found using:
LLOOP = pi * WCORE
Multiplying this length by the total number of loops gives the overall length of the first layer ( LLAYER1 = LLOOP * NLOOPS ). For the current example this would be LLAYER1 = 16 * pi * 0.01 = 0.5 metres.
Finding the Length of Subsequent Layers
If you look at the image, specifically where the second layer starts, you can see that each layer is added over the previous layer. This essentially means that each completed layer adds to WCORE by twice the diameter of the filament, 2 * DFIL. This can be seen on the image cross section by the filament of the first layer on either side of the tube. Hence to find the length of filament required to complete a certain layer, NLAYER you can use:
LLAYERN = ( 2 * NLAYER + WCORE ) * pi * NLOOPS
Continuing the example, the length of filament for the 2nd layer of the spool would be LLAYERN = ( 2 * 2 + 0.01 ) * pi * 16 = 0.8042477193 metres.
Calculating the Maximum Number of Layers
This is essentially the same as calculating the number of coils, except this time WOUTER is used as the ratioing edge:
NLAYERMAX = WOUTER / DFIL
Hence the maximum number of layers for the example are NLAYERMAX = 0.05 / 0.003 = 16 approximately. From here it would be possible to work out the total amount of filament the spool will hold or to create an algorithm to determine how many layers a certain length of filament would produce.
Notes
  • This information is a rewrite of This Link changing imperial to metric and, hopefully, being a little more descriptive.
  • These equations are generalised, for example the one working out the length of filament per coil does not take into account the extra small amount required to create the coil shape rather than a circle.
  • When I have a spare moment I shall try and create a spool calculator if desired.
Hope this helps,
Mac
July 21, 2012 04:24PM
What has the spool got to do with how long a certain weight of plastic is?
July 21, 2012 05:35PM
I see where I screwed up it was because I forgot to negative cube the 1240.
July 21, 2012 05:36PM
MacAleJam Wrote:
> With:
> mass = 1kg
> Diameter = 0.003 m
> by blue circles).
> [farm9.staticflickr.com]
> [*] HSPOOL = Spool wrapping height = 0.05 metres
> [*] WCORE = Diameter of the core (what the
> [*] WOUTER = Size of the flanges = 0.05 metres
> [*] DFIL = Diameter of filament = 0.003 metres
> each layer.
> using:
> LLOOP = pi * WCORE
> 0.5 metres.
> can use:
> Notes
> [*] This information is a rewrite of This Link
> [*] These equations are generalised, for example
> than a circle.
> [*] When I have a spare moment I shall try and
> Hope this helps,
> Mac
WOW, so detailed. Thank you because this will help me for some other stuff later that has zero to do with 3d printing.
July 21, 2012 06:22PM
That's what I was wondering...
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
July 22, 2012 05:54AM
maybe he wants to know how wide a spoolholder has to be for a certain amount (weight ) of filament......
July 22, 2012 06:02AM
Nothing to do with calculating a certain weight of plastic -- and sorry if it is too far off topic. In one of the posts above Dark Alchemist mentions having had difficulties with spool calculations. I'll happily delete the post if you all wish?
Edited 1 time(s). Last edit at 07/22/2012 06:42AM by MacAleJam.
July 22, 2012 07:09AM
No its useful information, I am just confused about what the original question was.
