See print layer November 11, 2015 01:51PM |
Re: See print layer November 11, 2015 02:38PM |
Re: See print layer November 11, 2015 03:06PM |
Re: See print layer November 11, 2015 03:19PM |
Re: See print layer November 11, 2015 03:21PM |
Re: See print layer November 12, 2015 02:46AM |
Re: See print layer November 12, 2015 02:58AM |
Re: See print layer November 12, 2015 06:51AM |
Re: See print layer November 12, 2015 08:24AM |
Re: See print layer November 12, 2015 11:51AM |
Re: See print layer November 12, 2015 01:43PM |
Re: See print layer November 12, 2015 02:42PM |
Re: See print layer November 12, 2015 04:34PM |
Re: See print layer November 12, 2015 09:35PM |
Re: See print layer November 13, 2015 02:32AM |
Paul Wanamaker
As J-Max said, 3500g seems very heavy. Others with your style of printer can comment (I have a delta).
What exact style is it?
To see if the weight is in fact the problem (as he stated) slow the print and travel speeds down! Very slow as a test. Example speeds: 30mms for printing, 60mms travel. Reduce the acceleration. You should tell us what speeds and acceleration you are using.
J-Max also said you may be printing too hot. It looks like you are printing PLA? At what Temperature? Using a cooling fan?
That is enough changes for one test. You don't need to print it very tall - enough to see if the layers stay even. Is it better?
As for tightening the timing belts, you can get a rough unscientific estimate of the tightness by plucking them like the string on a guitar. Do they produce a medium tone, or a very low tone? You should only be able to push the belt in a small amount with your finger.
We'll talk later about what motors you are using, and at what current.
Re: See print layer November 13, 2015 03:27AM |
ThanksQuote
bryanandaimee
It seems like we are having a hard time communicating, but I'll try again. Z Wobble is when the spinning Z screws cause the moving build plate to wiggle back and forth. It has nothing to do with how high your Z axis can go. If your Z lift screws are bent they can sometimes force the build plate out of place by a small amount. It doesn't take much movement to mess up your layer alignment. Are your Z screws secured in more than two places? Z screws should generally only be attached to the motor and to the build plate. If there is another bearing or bushing in the middle that may make things worse.
Try this. Make an X on your build plate. Bring it up to 0,0,0, and center the hot end on the X, then drive the build plate down and watch how the X moves versus the hot end. Does it seem to move straight down or does it also wobble back and forth as it goes down?
Bryan
Re: See print layer November 13, 2015 04:39AM |
Re: See print layer November 13, 2015 08:34PM |
Re: See print layer November 15, 2015 05:12AM |
Re: See print layer November 15, 2015 11:51AM |
Your question could have two meanings!Quote
Do you think delaminate due to high levels of Z-axis is the piece?
