Freezing and growling steppers, sainsmart, NEMA 17, A4988 Drivers, Arduino 2560 January 10, 2016 08:13AM |
Re: Freezing and growling steppers, sainsmart, NEMA 17, A4988 Drivers, Arduino 2560 January 11, 2016 03:27AM |
Re: Freezing and growling steppers, sainsmart, NEMA 17, A4988 Drivers, Arduino 2560 January 11, 2016 04:58AM |
Re: Freezing and growling steppers, sainsmart, NEMA 17, A4988 Drivers, Arduino 2560 January 11, 2016 06:28AM |
o_lampe
You are using these trapezoidal threads for XYZ axis?
Try to lower your max-speed and also the homing speed ( a lot, if you ask me )
Maybe start with 5mm/second.
Also reduce acceleration parameters by 50%
-Olaf
Re: Freezing and growling steppers, sainsmart, NEMA 17, A4988 Drivers, Arduino 2560 January 12, 2016 03:09AM |
//// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80.0,80.0, 4000.0, 93.0} //200.0*8/3,760*1.1} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {500, 500, 4, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Freezing and growling steppers, sainsmart, NEMA 17, A4988 Drivers, Arduino 2560 January 12, 2016 01:10PM |
o_lampe
These are the two lines for feedrate adjustment in configuration.h
When homing works, you can start with those settings for max_feedrate, too.
//// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0} // set the homing speeds (mm/min){50*60, 50*60, 4*60, 0} // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {1600,1600,1600,760*1.1} // default steps per unit for Ultimaker 78.7402 #define DEFAULT_MAX_FEEDRATE {100, 100, 5, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {50*60,50*60,50*60,1000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 50*60 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 50*60 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Freezing and growling steppers, sainsmart, NEMA 17, A4988 Drivers, Arduino 2560 January 13, 2016 04:16AM |
