Bed Adhesion Testing - Sitall and Wolfbite January 11, 2015 08:14PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite January 11, 2015 08:45PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite January 17, 2015 06:45PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite January 18, 2015 01:40AM |
Re: Bed Adhesion Testing - Sitall and Wolfbite February 02, 2015 03:10PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite March 05, 2015 05:04AM |
Re: Bed Adhesion Testing - Sitall and Wolfbite March 19, 2015 03:20PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite March 19, 2015 07:34PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite March 19, 2015 08:59PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite March 20, 2015 05:53AM |
Re: Bed Adhesion Testing - Sitall and Wolfbite November 26, 2015 02:08AM |
Re: Bed Adhesion Testing - Sitall and Wolfbite November 26, 2015 03:45AM |
I´m pretty sure you are not calibrating your printer in a good way.Quote
moonshine
I got a piece of Sitall galss and all I can tell you is that it's a scam... PLA/ABS sticks better to glass than to this... I finally switched to PET surface on aluminium and it work the best!!!! Waste of money with Sitall....
Re: Bed Adhesion Testing - Sitall and Wolfbite November 26, 2015 01:06PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite November 29, 2015 12:48PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite November 29, 2015 01:13PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite November 29, 2015 01:28PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite December 14, 2015 04:26AM |
Re: Bed Adhesion Testing - Sitall and Wolfbite December 20, 2015 03:29PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite December 20, 2015 03:32PM |
pabloevaristo
moonshine
The bed has to bed setup properly, once you do that sitall glass does its job great. I´ve been using it for the past 6 months and it´s working like a charm.
Re: Bed Adhesion Testing - Sitall and Wolfbite December 25, 2015 07:37PM |
Re: Bed Adhesion Testing - Sitall and Wolfbite December 26, 2015 11:31AM |
Re: Bed Adhesion Testing - Sitall and Wolfbite January 29, 2016 07:01AM |
Re: Bed Adhesion Testing - Sitall and Wolfbite January 31, 2016 02:20AM |
dtwrv6
So I ordered a sheet of Printbite for my Prusa i3, and have been experimenting with it for a couple of weeks. While I never had any issues with Sitall glass and ABS, I do like how much faster the Printbite heats up - glass is not a great heat conductor, so this makes sense. functionally, they are both more than adequate for ABS.
I have not had much luck getting polycarbonate to stick to the printbite though. Mutley - can you tell me how much experimenting you've done with PC before your determination that it works with the Printbite? I am using Gizmodorks PC, 130C bed, a 50-55C heated chamber, and bed levelling. I'm running about 20mm/s and the parts all start to pull away from the bed after about 5-20 layers. Right now I am using Wolfbite to enhance the adhesion which works extremely well, but I'd like to get away from an additional coating - especially a consumable one.
Don
