Power supply deal
Power supply deal
February 07, 2016 09:15PM
Meanwell supplies have a good reputation. Here's a 15V 13.4A (200W) supply for the same price as the low quality cheapies from ebay ($25):
[www.goldmine-elec-products.com]
Data sheet here:
[www.advice.co.il]
Mouser sells the same supply for $63.
Re: Power supply deal
February 07, 2016 11:25PM
Thanks DD but is that enough to run everything or just HB or mainboard? On an I3.
February 08, 2016 01:29AM
Since it can't be adjusted down to 12V, and 15V fans/heater cartridges are rare/expensive, am I right to assume this should be used just for the motors, and a different supply for heaters/fans (or with a buck converter)? Or do the heaters not really care about a bit higher/lower voltage since they're basically a wire resistor? Would the current they draw be a bit too much if used at 15V?
February 08, 2016 01:57AM
Yeah, I realized that after I posted and couldn't figure out how to delete the post. Nevermind...
