Problems with Larger Nozzles February 17, 2016 02:30PM |
Re: Problems with Larger Nozzles February 17, 2016 06:30PM |
Re: Problems with Larger Nozzles February 17, 2016 09:05PM |
Re: Problems with Larger Nozzles February 17, 2016 09:31PM |
Re: Problems with Larger Nozzles February 18, 2016 01:46AM |
Re: Problems with Larger Nozzles February 18, 2016 08:49AM |
Re: Problems with Larger Nozzles February 19, 2016 07:28AM |
Re: Problems with Larger Nozzles February 19, 2016 12:16PM |
Re: Problems with Larger Nozzles February 19, 2016 12:36PM |
Fan and ABS is a very big no-no it will warp so fast it can be used on starship enterpriseQuote
750magna
I'm printing in ABS. I'm going to try out printing with a fan blowing on the part, .
Please note that when using a large nozzle the total volume coming out of the nozzle is much higher then with the standard 0.4 nozzle. The temperature you are measuring at the nozzle is eaxtly that: nozzle temperature and not plastic temperature! So the filament has less time in the hotend to warm up and you will be extruding colder ABS then when using a smaller nozzle. That is the idea behind the volcano, larger heatblok and longer nozzle so there is more time for the filament to warm up and even then at 25mm/s and 260C the filament is still not that warm...Quote
750magna
I haven't used mine yet, just using the regular E3D with a .8mm nozzle. I'll keep that info in mind when I finally decide to set it up.
A 2 hour print at 100mm/s with the 0.4 nozzle is now a 1 hour print @ 25mm/sQuote
750magna
Going down to 25mm/s sounds like you'd give up most of the speed gains from the thicker layers though.
