Help adjusting the microstepping settings March 15, 2016 09:23AM |
Re: Help adjusting the microstepping settings March 15, 2016 12:11PM |
Re: Help adjusting the microstepping settings March 15, 2016 01:24PM |
Re: Help adjusting the microstepping settings March 15, 2016 02:09PM |
Re: Help adjusting the microstepping settings March 15, 2016 02:47PM |
JamesK
You'd get that with a short on ms1. For what it's worth I run the same setup with DRV8825, 1/32 microstepping, mega/ramps and have used both Marlin and Repetier firmware with no signs of step rate problems at travel speeds of 250mm/s, so I doubt if maximum step rate is your problem. And if it was, you'd easily be able to tell because the problem would go away if you dropped your speeds.
Re: Help adjusting the microstepping settings March 15, 2016 02:49PM |
Re: Help adjusting the microstepping settings March 18, 2016 12:14PM |
