Question on heated beds and LCD's. (Very general questions) April 17, 2016 06:13PM |
Re: Question on heated beds and LCD's. (Very general questions) April 17, 2016 06:43PM |
Re: Question on heated beds and LCD's. (Very general questions) April 17, 2016 07:34PM |
Re: Question on heated beds and LCD's. (Very general questions) April 17, 2016 07:55PM |
the_digital_dentist
I print exclusively from SD cards using the LCD panel on my SmoothieBoard. It is the most reliable way to print.
Re: Question on heated beds and LCD's. (Very general questions) April 18, 2016 05:46AM |
Re: Question on heated beds and LCD's. (Very general questions) April 18, 2016 01:55PM |
Re: Question on heated beds and LCD's. (Very general questions) April 18, 2016 01:57PM |
the_digital_dentist
I think that 1/4" plate that size should be OK. It is stiff enough that it won't sag much, so as long as you print with first layer thickness 200-250 um you should be able to print nearly edge to edge. I did some measurements of bed flatness (combined with X axis and Y axis sag, etc.) on my printer and posted video here:
heated: [vimeo.com]
unheated: [vimeo.com]
The bed is 1/4" cast tooling plate. Don't use any other kind of aluminum- it won't be flat. I print right on the aluminum plate covered with kapton tape- no glass- I don't see the point in using it.
I have a 450W heater on my 317 x 305 mm bed and it heats to 105C for printing ABS in about 5 minutes. That's about 0.5 W/cm^2. Use a similar power density to achieve similar wait time.
Four point systems bend the bed plate and or undercarriage more than they level anything. Use a 3 point leveling system as it actually levels the bed without bending it or the undercarriage.
Re: Question on heated beds and LCD's. (Very general questions) April 18, 2016 02:13PM |
Re: Question on heated beds and LCD's. (Very general questions) April 18, 2016 03:20PM |
WalkerMaker
Also, why an IR probe when there are inductive sensors/mechanical switches/ and even hall effect sensors?
Re: Question on heated beds and LCD's. (Very general questions) April 18, 2016 03:27PM |
