Avoid end switch adjustments in delta
Posted by Pawan
May 01, 2016 04:08AM
Do we need to have an end stop height adjustment on a delta printer with auto bed leveling?
Re: Avoid end switch adjustments in delta
May 01, 2016 04:14AM
No, even if you are doing manual calibration. All modern delta printer firmwares support the M666 command for adjusting the end stop offsets. It helps if you can get the endstop trigger heights within 1mm of each other by adjusting the positions of the endstop switches.
