Lower resolution killing Z axis movment
Posted by mattbatt84
July 07, 2016 05:18PM
Good day to you all. Strange issue with my build. When I print a cube 20mm on 0.3 resolution it prints perfectly.
If I change the resolution 0.2 the z axis does not move. I keep my hand on the lead screw to see if I can feel it move and it does not. This is the same for 0.1 resolution
Does anybody have any ideas.
Re: Lower resolution killing Z axis movment
July 08, 2016 04:19AM
We need to know a lot more about your printer in order to help, in particular the Z axis movement mechanism.
July 08, 2016 12:58PM
SWAG: your z stepper drivers are set for full steps instead of the usual 16 microstepping and the 0.3 layers happen to be a full step...
Or the gonqulator needs adjusting... :-)
July 08, 2016 01:44PM
Check and make sure you have 3 jumpers placed under each motor driver.
This is assuming you have a ramps board.
