I recently purchased the A8 Prusa i3 clone as my first 3D printer, and this particular one came with the AnetV1.0 board.... unfortunately, I already ran into an issue. The heated bed worked for part of the first print, and now reads incorrectly. I measured the thermistor, and tested the bed seperate on my bench power supply and it works/measures out the correct resistance. After measuring the capacitors, I feel that the heat bed control circuit has faulty components... Does anyone know where I may purchase one of these boards? Or should I simply upgrade to a different one?
Thank you in advanced,
Brandon
