connecting and construction of cables for rep rap.
August 11, 2012 01:06PM
Hi, all.
I building a rep rap and, I can't find any manual which would describe in detail, how to make rep rap cables and how to wire them.
I mean how to make cable, from wire, electro motor, some plastic 4-pin frame and some metal connector.
Thank you for yours time.
open | download - Slika009.jpg (199.1 KB)
Re: connecting and construction of cables for rep rap.
August 11, 2012 01:38PM
Maybe this video is what you are looking for: [www.youtube.com]
August 11, 2012 05:08PM
I went thru this problem myself.
The first mistake I made is that I bought AWG 18 gauge wire. This caused lots of issues with crimp connectors.
I finally mounted my RAMPS1.4 to the frame using a wood board, and switched to AWG 22 gauge (22/4 shielded security wire). This wire is easy with crimp connectors.
It does not matter where you mount the electronics so long as the wires do not move relative to it (causes contact problems). You can then measure the wire from there to your motors and endstops. Mark your cables before connecting them to avoid confusion later. Taping them with clear tape also helps before using using zip ties.
Get yourself a good wire stripper like in the video posted by misan.
August 12, 2012 05:50AM
Thank you for answers and video.
Here are some wire schematics ...
[reprap.org]
[reprap.org]
