Glass thickness question November 20, 2016 11:33AM |
Re: Glass thickness question November 20, 2016 12:46PM |
If you intend to have an inductance probe the the glass needs to be less then 4mm.Quote
WZ9V
I have a 200x300mm PCB style heated bed which is supported at the four corners. What thickness of glass should I use for that size bed?
I'm currently using standard window pane glass from the h/w store and I'm seeing a bit of sag in the middle when printing things that are close to the 300mm length.
Re: Glass thickness question November 20, 2016 01:31PM |
Re: Glass thickness question November 20, 2016 02:16PM |
Re: Glass thickness question November 20, 2016 05:17PM |
Re: Glass thickness question November 20, 2016 08:46PM |
Re: Glass thickness question November 20, 2016 09:34PM |
Re: Glass thickness question November 20, 2016 09:49PM |
WZ9V
What thickness aluminum would be good?
Re: Glass thickness question November 21, 2016 09:13AM |
WZ9V
Re: Glass thickness question November 21, 2016 10:50PM |
