MXL vs GT2 belt stiffness December 17, 2016 11:42PM |
Re: MXL vs GT2 belt stiffness December 19, 2016 05:43PM |
Re: MXL vs GT2 belt stiffness December 19, 2016 05:48PM |
DragonFire
The resistance to stretching is mostly down to what sort of stiffener a belt has embedded in it. Some have steel or carbon fiber embedded.
There is wide variation between the different variations, even within the GT2 range, let alone comparing it to other types of belt.
Re: MXL vs GT2 belt stiffness December 19, 2016 09:18PM |
Re: MXL vs GT2 belt stiffness December 19, 2016 10:04PM |
obelisk79
Given the same materials used for production, there should be little to no difference in equal width/length belts. Any difference at that point would come down to quality control or amount of embedded fiberglass which I imagine would vary based on factory it was produced in. The real difference would be in looking at other core materials as mentioned above.
Re: MXL vs GT2 belt stiffness December 20, 2016 10:04PM |
Re: MXL vs GT2 belt stiffness December 20, 2016 10:10PM |
Re: MXL vs GT2 belt stiffness December 21, 2016 12:55AM |
obelisk79
Fair enough, being the manufacturer I'd lean towards believing their numbers as well. I am going to be switching from mxl belts to gt2 in a couple of weeks hopefully. But it will be coming along with a redesign of my mechanical motion as I frankenstein my CubeX into a CoreXY machine I've dubbed the CubeXY Project. I'm not sure if it would really be useful as a direct comparison between the belts in terms of real world performance. Additionally it'd probably just be best to do a true stretch test. take 1M of each type of belt and attach weights to them to test the amount of stretch for a given weight. It would be relatively simple to do. If I have any GT2 left over after my conversion I'll gladly set a simple test up to make a comparison and provide my results here.
