Only the Extruder not running, new machine, using replicatorg
August 16, 2012 01:13PM
Hi everybody,
I seem to have a problem that doesn't occur that often. Many topics have been regarded and hours been spend, yet no solution has been found. If anybody can be of help, i highly appreciate it! If you would recommend a different combination, please note the why as well winking smiley
The problem:
My extruder stepper won't run, al the other steppers run beatifuly and the temperatures are kept beautifully constant. The strange thing however is that this only happens with the rapligatorg software (compared to Cura).
Spec's:
  • Ramps_V1.4, (with polulu steppers) (two extruder outputs, E0 in use)
  • Wades extruder
  • Marlin 1.0.0 release candidate 2
  • oftware, replicatorg/cura 12.08 Replicatorg machine: mendel with mega/ramps electronics (57900 baud)
Checks used:
  • Checked stepper and motor for defects by swapping components, everyting ok.
  • I have checked the pinlayout in the marlin firmware.
  • By running the Cura 12.08 supplied printrun program I mangaged to use the extruder, no problem, therefore no hardware is damaged (e.g. stepper driver, mega, or ramps board) and the designated pins are ok.
  • obbeying the min temperature of 170° (also in Cura ofcourse).
The question:
Could anyone help me to get the replicatorg software to work with the extruder?
Since I have the 3D printer working with cura, I might continue with this software. Yet I find that the replicatorg software should work to. And if the solution is found, this of course will be handy for future DIY'rs whom will want to use the same combination.
For reviewing purposes, the configuration.h file from marlin has been included below:
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
// This configurtion file contains the basic settings.
// Advanced settings can be found in Configuration_adv.h
// BASIC SETTINGS: select your board type, temperature sensor type, axis scaling, and endstop configuration
//User specified version info of THIS file to display in [Pronterface, etc] terminal window during startup.
//Implementation of an idea by Prof Braino to inform user that any changes made
//to THIS file by the user have been successfully uploaded into firmware.
#define STRING_VERSION_CONFIG_H "2012-08-11" //Personal revision number for changes to THIS file.
#define STRING_CONFIG_H_AUTHOR "Stefan" //Who made the changes.
// This determines the communication speed of the printer
//#define BAUDRATE 250000
//#define BAUDRATE 115200
#define BAUDRATE 57600
//// The following define selects which electronics board you have. Please choose the one that matches your setup
// Gen7 custom (Alfons3 Version) = 10 "https://github.com/Alfons3/Generation_7_Electronics"
// Gen7 v1.1, v1.2 = 11
// Gen7 v1.3 = 12
// Gen7 v1.4 = 13
// MEGA/RAMPS up to 1.2 = 3
// RAMPS 1.3 = 33 (Power outputs: Extruder, Bed, Fan)
// RAMPS 1.3 = 34 (Power outputs: Extruder0, Extruder1, Bed)
// Gen6 = 5
// Gen6 deluxe = 51
// Sanguinololu 1.2 and above = 62
// Melzi = 63
// Ultimaker = 7
// Teensylu = 8
// Gen3+ =9
#ifndef MOTHERBOARD
#define MOTHERBOARD 34
#endif
//=============================Thermal Settings  ============================
//--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
//// Temperature sensor settings:
// -2 is thermocouple with MAX6675 (only for sensor 0)
// -1 is thermocouple with AD595
// 0 is not used
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
// 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
// 3 is mendel-parts thermistor (4.7k pullup)
// 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
// 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
//    1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k
//                          (but gives greater accuracy and more stable PID)
// 51 is 100k thermistor - EPCOS (1k pullup)
// 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
// 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan) (1k pullup)
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 0
// Actual temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 10	// (seconds)
#define TEMP_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_WINDOW     1       // (degC) Window around target to start the recidency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 255
#define HEATER_1_MAXTEMP 255
#define HEATER_2_MAXTEMP 255
#define BED_MAXTEMP 150
// PID settings:
// Comment the following line to disable PID and enable bang-bang.
#define PIDTEMP
#define PID_MAX 255 // limits current to nozzle; 255=full current
#ifdef PIDTEMP
  //#define PID_DEBUG // Sends debug data to the serial port.
  //#define PID_OPENLOOP 1 // Puts PID in open loop. M104 sets the output power in %
  #define PID_INTEGRAL_DRIVE_MAX 255  //limit for the integral term
  #define K1 0.95 //smoothing factor withing the PID
  #define PID_dT ((16.0 * 8.0)/(F_CPU / 64.0 / 256.0)) //sampling period of the
// If you are using a preconfigured hotend then you can use one of the value sets by uncommenting it
// Ultimaker
//    #define  DEFAULT_Kp 22.2
//    #define  DEFAULT_Ki 1.08
//    #define  DEFAULT_Kd 114
// Makergear
//    #define  DEFAULT_Kp 7.0
//    #define  DEFAULT_Ki 0.1
//    #define  DEFAULT_Kd 12
// Mendel Parts V9 on 12V, costumized on 16-08-2012
   #define  DEFAULT_Kp 15.0
   #define  DEFAULT_Ki 1.25
   #define  DEFAULT_Kd 220
#endif // PIDTEMP
//this prevents dangerous Extruder moves, i.e. if the temperature is under the limit
//can be software-disabled for whatever purposes by
#define PREVENT_DANGEROUS_EXTRUDE
//if PREVENT_DANGEROUS_EXTRUDE is on, you can still disable (uncomment) very long bits of extrusion separately.
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MINTEMP 170
#define EXTRUDE_MAXLENGTH (X_MAX_LENGTH+Y_MAX_LENGTH) //prevent extrusion of very large distances.
//=============================Mechanical Settings===========================
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
// corse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
  // fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined
  #define ENDSTOPPULLUP_XMAX
  #define ENDSTOPPULLUP_YMAX
  #define ENDSTOPPULLUP_ZMAX
  #define ENDSTOPPULLUP_XMIN
  #define ENDSTOPPULLUP_YMIN
  //#define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Y_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
const bool Z_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops.
//#define DISABLE_MAX_ENDSTOPS
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define INVERT_X_DIR true    // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR false    // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR false     // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false   // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false    // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false   // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops true //If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true  //If true, axis won't move to coordinates greater than the defined lengths below.
// Travel limits after homing
#define X_MAX_POS 195
#define X_MIN_POS 0
#define Y_MAX_POS 195
#define Y_MIN_POS 0
#define Z_MAX_POS 200
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
// The position of the homing switches. Use MAX_LENGTH * -0.5 if the center should be 0, 0, 0
#define X_HOME_POS 0
#define Y_HOME_POS 0
#define Z_HOME_POS 0
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {50*60, 50*60, 4*60, 200}  // set the homing speeds (mm/min)
// default settings
//#define DEFAULT_AXIS_STEPS_PER_UNIT   {78.7402,78.7402,200*8/3,760*1.1}  // default steps per unit for ultimaker
#define DEFAULT_AXIS_STEPS_PER_UNIT   {78.7402,79.89506,200*8/3,760*1.1}  // calibrated using calibratie printer 16-08-2012.xlxs
#define DEFAULT_MAX_FEEDRATE          {500, 500, 5, 45}    // (mm/sec)
#define DEFAULT_MAX_ACCELERATION      {9000,9000,100,10000}    // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION          3000    // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION  3000   // X, Y, Z and E max acceleration in mm/s^2 for r retracts
#define DEFAULT_XYJERK                20.0    // (mm/sec)
#define DEFAULT_ZJERK                 0.4     // (mm/sec)
#define DEFAULT_EJERK                 5.0    // (mm/sec)
//=============================Additional Features===========================
// EEPROM
// the microcontroller can store settings in the EEPROM, e.g. max velocity...
// M500 - stores paramters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings".  You still need to store them in EEPROM afterwards if you want to.
//define this to enable eeprom support
//#define EEPROM_SETTINGS
//to disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out:
// please keep turned on if you can.
//#define EEPROM_CHITCHAT
//LCD and SD support
//#define ULTRA_LCD  //general lcd support, also 16x2
//#define SDSUPPORT // Enable SD Card Support in Hardware Console
//#define ULTIMAKERCONTROLLER //as available from the ultimaker online store.
//#define ULTIPANEL  //the ultipanel as on thingiverse
#ifdef ULTIMAKERCONTROLLER    //automatic expansion
 #define ULTIPANEL
 #define NEWPANEL
#endif
#ifdef ULTIPANEL
//  #define NEWPANEL  //enable this if you have a click-encoder panel
  #define SDSUPPORT
  #define ULTRA_LCD
  #define LCD_WIDTH 20
  #define LCD_HEIGHT 4
// Preheat Constants
  #define PLA_PREHEAT_HOTEND_TEMP 180
  #define PLA_PREHEAT_HPB_TEMP 70
  #define PLA_PREHEAT_FAN_SPEED 255		// Insert Value between 0 and 255
  #define ABS_PREHEAT_HOTEND_TEMP 240
  #define ABS_PREHEAT_HPB_TEMP 100
  #define ABS_PREHEAT_FAN_SPEED 255		// Insert Value between 0 and 255
#else //no panel but just lcd
  #ifdef ULTRA_LCD
    #define LCD_WIDTH 16
    #define LCD_HEIGHT 2
  #endif
#endif
// Increase the FAN pwm frequency. Removes the PWM noise but increases heating in the FET/Arduino
#define FAST_PWM_FAN
// M240  Triggers a camera by emulating a Canon RC-1 Remote
// Data from: [www.doc-diy.net]
// #define PHOTOGRAPH_PIN     23
#include "Configuration_adv.h"
#include "thermistortables.h"
#endif //__CONFIGURATION_H
Re: Only the Extruder not running, new machine, using replicatorg
August 16, 2012 04:15PM
From what I understand you need a "custom" xml config file to run a RepRap from repg.
I suggest you stay with Cura, or use Pronterface or Repetier with Slic3r.
-Nudel
Blog with RepRap Comic
August 17, 2012 08:57AM
Hi Nudel, thanks for the input. What are you're experiences with cura or Repetier, wich one would you prefer?
xml was the keyword in this case, since it is a lot of work (from what I can find) and I have only basic code experience I shall not try to get replicatorg working...
August 17, 2012 12:38PM
There are plenty of ready-made xml config files around, I've seen them linked on the forum several times. But - to be a bit brutal - why bother using time on software that isn't compatible with RepRap in the first place.
I personally prefer slic3r + pronsole.py (the console version of pronterface, running on a headless raspberry pi), but still use the pronterface gui to preview the gcode.
Cura is nice, but since it uses skeinforge at the base, it still has some of the old issues from skeinforge. I especially don't like how it fill the entire layer if there's a bridge. I haven't used Cura for an actual print, but the 3D gcode preview is neat.
I haven't tried Repetier myself, but it gets some good press, and looks very nice.
My suggestion is to start with slic3r and pronterface, it's simple and straight to the point.
-Nudel
August 17, 2012 02:18PM
Than I'l start with slic3r and pronterface and probably will check out repetier, thanks for your time and advice!
August 17, 2012 02:35PM
Glad to be of assistance. smiling smiley Welcome to the RepRap community!
-Nudel
