Timing belt Vs fishing line April 29, 2016 10:21AM |
Re: Timing belt Vs fishing line April 29, 2016 10:24AM |
Re: Timing belt Vs fishing line April 29, 2016 11:10AM |
Re: Timing belt Vs fishing line April 29, 2016 11:36AM |
Re: Timing belt Vs fishing line April 29, 2016 12:38PM |
Re: Timing belt Vs fishing line April 29, 2016 12:44PM |
Re: Timing belt Vs fishing line April 29, 2016 12:50PM |
Admin Registered: 16 years ago Posts: 13,873 |
Re: Timing belt Vs fishing line April 29, 2016 12:53PM |
Re: Timing belt Vs fishing line April 29, 2016 02:50PM |
Re: Timing belt Vs fishing line April 29, 2016 02:51PM |
Re: Timing belt Vs fishing line April 29, 2016 03:08PM |
Re: Timing belt Vs fishing line April 29, 2016 03:13PM |
Re: Timing belt Vs fishing line April 29, 2016 03:16PM |
Re: Timing belt Vs fishing line April 29, 2016 03:22PM |
Re: Timing belt Vs fishing line April 29, 2016 04:18PM |
Re: Timing belt Vs fishing line April 29, 2016 07:43PM |
Re: Timing belt Vs fishing line April 30, 2016 06:07AM |
Re: Timing belt Vs fishing line April 30, 2016 05:16PM |
Re: Timing belt Vs fishing line May 01, 2016 02:57PM |
Re: Timing belt Vs fishing line May 01, 2016 03:15PM |
Re: Timing belt Vs fishing line May 01, 2016 05:59PM |
Re: Timing belt Vs fishing line May 01, 2016 07:40PM |
Re: Timing belt Vs fishing line May 01, 2016 08:01PM |
Re: Timing belt Vs fishing line May 02, 2016 07:48AM |
Re: Timing belt Vs fishing line May 02, 2016 11:34AM |
Re: Timing belt Vs fishing line May 02, 2016 01:36PM |
leadinglights
Never knowing what to expect with modern materials and having some very similar size steel and Spectra fishing line I checked them out. I tied a 5 meter length of each to a door handle with the other end on a cross piece made from a length of 3mm studding. The cables were 40mm apart and at the center point I had a 20N dynamometer (posh name for a spring scale) Starting with a preload of 2 Newtons where I the two lengths to be equal, I then increased the load by 20 Newtons (about 2kg). The steel stretched by 4mm and the Spectra by 7mm. increased. Both figures are very good and definitely usable although Spectra suffers from creep of about 2% per year at its rated working load.
[attachment 77387 20160501_1956511.jpg]
The spectra was 0.55mm diameter 100lb Spectra Extreme Braid. The Steel consisted of 7 bundles of 7 strands for a total diameter of 0.54mm in a 0.7mm diameter Nylon jacket.
Mike
Re: Timing belt Vs fishing line May 02, 2016 03:01PM |
Re: Timing belt Vs fishing line May 02, 2016 03:09PM |
Re: Timing belt Vs fishing line May 02, 2016 03:11PM |
Re: Timing belt Vs fishing line May 02, 2016 04:46PM |
