I am wanting to change the position of the 1st and 2nd extruders on my graphic LCD screen ( 2 on the left, 1 on the right )
I have traced the source of the extruder image that appears on the LCD. The numbers are, best I can tell, part of the image.
What software can I use to edit the following bmp code so I can move or edit the image parts, etc.
I am using Windows.
Ideally somethng where I can paste this code from the firmware, and have it display a grid of black / white or on / off squares in a grid format where I can toggle the pixels on and off.
#define STATUS_SCREENWIDTH 115 //Width in pixels
#define STATUS_SCREENHEIGHT 19 //Height in pixels
#define STATUS_SCREENBYTEWIDTH 15 //Width in bytes
const unsigned char status_screen0_bmp[] PROGMEM = { //AVR-GCC, WinAVR
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xE0,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xE0,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x63,0x0C,0x60,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x47,0x0E,0x20,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4F,0x0F,0x20,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5F,0x0F,0xA0,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5E,0x07,0xA0,
0x7F,0x80,0x00,0x3F,0xC0,0x00,0x00,0x00,0x00,0x41,0x04,0x00,0x40,0x60,0x20,
0xFB,0xC0,0x00,0x79,0xE0,0x00,0x00,0x00,0x00,0x20,0x82,0x00,0x40,0xF0,0x20,
0xF3,0xC0,0x00,0x76,0xE0,0x00,0x00,0x00,0x00,0x20,0x82,0x00,0x40,0xF0,0x20,
0xEB,0xC0,0x00,0x7E,0xE0,0x00,0x00,0x00,0x00,0x41,0x04,0x00,0x40,0x60,0x20,
0x7B,0x80,0x00,0x3D,0xC0,0x00,0x00,0x00,0x00,0x82,0x08,0x00,0x5E,0x07,0xA0,
0x7B,0x80,0x00,0x3B,0xC0,0x00,0x00,0x00,0x01,0x04,0x10,0x00,0x5F,0x0F,0xA0,
0xFB,0xC0,0x00,0x77,0xE0,0x00,0x00,0x00,0x01,0x04,0x10,0x00,0x4F,0x0F,0x20,
0xFB,0xC0,0x00,0x70,0xE0,0x00,0x00,0x00,0x00,0x82,0x08,0x00,0x47,0x0E,0x20,
0xFF,0xC0,0x00,0x7F,0xE0,0x00,0x00,0x00,0x00,0x41,0x04,0x00,0x63,0x0C,0x60,
0x3F,0x00,0x00,0x1F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xE0,
0x1E,0x00,0x00,0x0F,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0x80,0x7F,0xFF,0xE0,
0x0C,0x00,0x00,0x06,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0x80,0x00,0x00,0x00
