Small homes (and curves in gen)
August 18, 2012 05:20PM
(Prusa, Gen 6-Sprinter, Ponterface/Splic3r)
I've found the machine does some random (when and how long) micro-pauses when doing curves/radius.
This normal? I find it hard (but not impossible) to believe its a PC->Gen6 coms prob.
Alos on small holes/radius, < 4mm Dia, it goes so slow it goobers up. I've kludged a fix of just making them square holes. The 2mm holes come out pretty much round, and just a quick clean up with a drill bit (I do that with most all holes anyways)
So, my big question is why does the feed rate drop so much on a radius? And can I adjust the extruder rate during a radius?
I might go back to SFACT and se if that does any better. But I think its in the firmware.
Re: Small homes (and curves in gen)
August 18, 2012 05:30PM
What do you have the baud rate set at?
August 18, 2012 06:41PM
Two thing can make slic3r slow things down dramatically, you're small perimeter speed and the minimum layer time.
The stopping is a problem with the firmwares buffer running our of print commands, this is a function of the serial connection between sprinter and pronterface. If the baud rate is too high, you can get a lot of errors and see this happen, it also happens if it's not high enough.
August 18, 2012 07:48PM
AH! Missed that small perimeter speed. Gosta play. smiling smiley thanks
Whats the 'cut-off' to be 'small perimeter/?
(Baud is the standard 38K for this firmware. I try not to mess too much with it. I'm PIC man, not audrino )
August 18, 2012 07:54PM
38K is very low, most people run at either 250K or 115200.
You need recompile the firmware to change it
August 18, 2012 07:59PM
As Polygonhell said, you need to increase the baud rate. 115200 should be fast enough to avoid the pauses you are getting, even with very short segments. 38k won't cut it.
August 18, 2012 08:03PM
Ok will up the baud. I gotta tweak the axis anyways.
Is this normal for re-flashing?
I need to unplug the USB and power cylce the board to get the software to upload the new firmware. If I do just one of those, no-go. (dang, I struggled over that one for a stretched smiling smiley )
August 18, 2012 08:05PM
If the board doesn't auto-reset (I'm not sure if Gen6 does) then it's normal. If it has a reset button you can push that as soon as the Arduino IDE says "Done Compiling" as well.
